sanderb 0 Report post Posted May 6, 2019 Hello all, i have recently bought a Sony MDS-PC2 with the connection kit PCLK-MD2 (CAV-50C, see here: http://www.minidisc.org/part_Sony_PCLK-MD1+MD2.html). But there's the CD missing which contains the MD Editor 2 software. Now I have searched the internet everywhere for this software (and others) to be able to edit the titles on minidiscs using this Sony and a computer - but to no avail. is there anybody that can help? Many thanks in advance! Sander. Quote Share this post Link to post Share on other sites
Fredamixx 0 Report post Posted September 21, 2019 I have the original CD Quote Share this post Link to post Share on other sites
KeesNL 0 Report post Posted June 11, 2020 I am in the same position. Bought a MDS-PC2 with the CAV-50C and all manuals, but the CD is missing. I think Sony will not be able to send me a copy, so if anyone can help me out it would be great. Quote Share this post Link to post Share on other sites
kgallen 5 Report post Posted June 11, 2020 Have you had a look in the Downloads section? (Tab at the top of this page) I have no clue - but is this something different to SonicStage? There is some stuff called M-Crew in Downloads too, it that it? Sorry... Stephen will be here is a minute to give you the proper answer. Poooof... as if by magic... Quote Share this post Link to post Share on other sites
sfbp 8 Report post Posted June 11, 2020 I doubt if you actually need the CD. Just looked it up... it's a Ctrl-A1II hookup. Quote Share this post Link to post Share on other sites
KeesNL 0 Report post Posted June 11, 2020 Thanks for the quick answers. I have installed Mcrew, but this would not install on my Win10 machine. Also installed SonicStage, but as soon as I start this, an error occurs (also after a reboot). So I have powered up an old Windows XP sp3 virtual machine and installed both programs. M-crew installs, but as soon as I start the program an error occurs (some DLL is missing it reports). SonicStage is working on XP, but I can't find any way to connect to my MD. What I would like to do is edit the TOC of my minidisc. I understand I do not need the CD, but only the program or a replacement. Quote Share this post Link to post Share on other sites
NGY 24 Report post Posted June 11, 2020 I read this quite a while ago - might be worth a few minutes to quickly read through, if it can help. Quote Share this post Link to post Share on other sites
NGY 24 Report post Posted June 11, 2020 41 minutes ago, KeesNL said: M-crew installs, but as soon as I start the program an error occurs (some DLL is missing it reports) If I remember correctly, M-Crew is looking for the CAV-MN10 interface - that is an USB box, and as such, it needs the appropriate dll-s installed. Quote Share this post Link to post Share on other sites
sfbp 8 Report post Posted June 11, 2020 Neither SonicStage nor M-Crew will talk to the PC2. You can get SonicStage working nicely on Windows 64 (or 32) but the problem is your device doesn't speak either PS/2 (M-Crew) or USB (Sonic Stage). Sorry! I *think* maybe the Onkyo stuff still supports Ctrl-A1 II, but not sure if their flavour is compatible with the Sony (SIRCS) variety. Everything changed so fast as the world evolved to new standards such as USB 2. *IFF* all you need is good track titling, what about the remote with keyboard, the RM-D10P? http://minidisc.org/part_Sony_RM-D10P+D11P+D20P.html At least the MDS-PC2 has lots of input and output, though the review Gyula linked to seems to indicate optical input might be a bit of a nuisance. Perhaps that's one thing that's better in 2020. No real experience with the MDS-PC2. I have its successor, the PC3 and it works really nicely. Quote Share this post Link to post Share on other sites
sfbp 8 Report post Posted June 12, 2020 Hmm, did some checking. Did you look here? http://www.minidisc.org/part_Sony_PCLK-MD1+MD2.html There's what you're looking for. You will need a serial cable connection which most PCs don't have these days, but I expect you're all organized in that department. Good luck! Quote Share this post Link to post Share on other sites
KeesNL 0 Report post Posted June 15, 2020 Thanks sfbp! This article has a link to the local archive and I was able to download the MD Editor 2 software from there. I tried to install it on Windows 10 (in XP compatible mode) but without success. So I got back to my previous mentioned virtual XP machine and I was able to install the software. Because I do have a serial port on my computer and I did already shared this port with my virual machine (software for my old Philips Pronto is also using the serial connection and does not work stable in Windows 10) the software is working. The interface is a bit hard to understand, but it works! So all you need is the software, a windows XP machine with a serial port and you are good to go. Thanks all for your help. Quote Share this post Link to post Share on other sites
sfbp 8 Report post Posted June 15, 2020 A side note, there are serial port emulators these days, that plug into a USB 2.0 port. I'd also lay money on the problem being you need a 32-bit version of W10 - not that hard to come by. Quote Share this post Link to post Share on other sites
sanderb 0 Report post Posted January 10 Many thanks sfpb - had it put aside, but now I can get going again and I guess I'll still give Win10 a try to get it to work. Else I need to go with KeesNL and utilize WinXP somehow. Both much appreciated! Quote Share this post Link to post Share on other sites
sfbp 8 Report post Posted January 10 Most W10 are upgrades. Not sure how you force W10 to go into 32-bits though. The ones I have dealt with mainly got there because someone had 32-bit Win7 before that, and upgraded it. Quote Share this post Link to post Share on other sites
