Sony Insider Forums
Sign in to follow this
Corbs
Sony MZ-G750 - Optical Cable Connection
Hi have a fully-working Sony MZ-G750. The two inputs for recording are labelled MIC (plug in power) and Line In (optical).  They both look to me like a standard 3.5mm jack, but what 'digital' cable would be used to record into the Line In (optical) input?
Thanks!
Share this post
You can use either a 3,5 mm jack / TOSLINK optical cable, or a 3,5 mm jack to TOSLINK female plug and a regular TOSLINK/TOSLINK optical cable:
1.jpg.56ae2f9c24683f262ae81215d009f6d2.jpg  or   2.jpg.dabbf99efa069595bc3f2c09d8c4f72e.jpg   3.jpg.e059a23decdbd7715974008ea29c9b89.jpg
Share this post
Ah, OK, thank you!  I can't recall one of these coming with the device when i bought it new, even though the manual implies there would have been one.  So the TOSLINK end would go into the audio-out of another device - would that be a 'digital' feed then (sorry for my ignorance!)?
Share this post
39 minutes ago, Corbs said:
So the TOSLINK end would go into the audio-out of another device - would that be a 'digital' feed then ?
Correct. If the source device has a TOSLINK digital audio output, you can record that audio with your MZ-G750 digitally.
Beware though the SCMS rules/limitations.
Share this post
Please note that the (optical) socket doubles as a standard stereo line input when you insert a normal 3.5mm jack. This is not coax digital but line-in analogue.
Share this post
