How Long For Sp On A Standard Md Reformatted To Himd
Sparky191
Two thoughts come to mind. One, the unit won't let you record in SP on a Hi-MD formatted disc (only PCM, Hi-SP, or Hi-LP). Two, if you use SonicStage to move record in SP, folks have said that SS converts it to LP2 before going to SP. That's not better sound quality at all. I haven't checked for myself yet, but I think you would get comparable sound quality between SP and Hi-SP based on what others have said here. Either way, I would suggest trying for yourself and seeing what works for you.
Indeed, there is no SP recording in HiMD mode.
If you are recording from analogue or optical in on the unit itself, you can either choose to use netMD mode [with true SP, MDLP, type R and type S, correct?] or HiMD mode [with PCM, HiSP, and HiLP].
From SinceStage, there is no actual SP mode. You can, however, write any [atrac] format that you can encode to in SS to a HiMD-formatted disc, meaning, for example, that you can use LP2 [as many do].
If you are recording SP onto a standard MD reformatted to HiMD. How much recording time do you have. SP being better quality than HiSP from what I'm reading here.
SP is not available in Hi-MD-mode.
You are using Hi-SP.
Running times:
60min = 1h 45m
74min = 2h 10m
80min = 2h 20m
1GB = 7h 55m
If you want to use normal SP, you have to switch back to
normal MD - mode (NetMD in SonicStage)
You have of course the same running times as with every old
MD recorder. And of course no 1GByte discs.
And no upload either. And no real SP from SonicStage.
My advice: Use Hi-SP. And PCM for some very critical recordings.
  • 3 weeks later...
^ 94.55 minutes.
That's a good time IMO, about equivalent to a 90 minute tape, for us old-timers who can remember (and still use) such things...
Some think that standard SP is better than Hi-SP, by the way. Personally I don't think there's a significant difference in quality...
or if there is its very minimal
also why Sony doesn't let you nativly use MDSP or at the very least MDLP on a HiMD formatted disc is beyond me. Especially with SonicStage the way it is
