Hat Trick For MDCF? - Service Mode + 2nd Gen Hi-MD
We did it for the MZ-R900/700/500, again for first generation Hi-MD, and now..
With frightening restrictions facing Europeans such as reduced output [2.8mW], and no real custom equalizer on the MZ-RH10 and presumeably other second generation Hi-MD units, can we save the masses once again?
Here's how you remove this limitation - by entering service mode you take full responsibility for your actions and cannot hold minidisc.org or it's associates liable for any damages occured - don't worry though, you'll be fine:
With the 'Hold' switch on, and while pressing 'Menu', press FF FF RW RW FF RW FF RW Pause Pause.
[FF = Fast Forward | RW = Rewind]
1.) Press the 'Vol +' key to enter the Manual mode.
2.) Press the 'FF' key five times to select the item number 0113.
3.) Press the 'Vol +'/'Vol -'key and set the value that is after "DistFL", or if you don't see that, when you press 'Vol +'/'Vol -' a value will increase/decrease - change it to 24.
4.) Press the 'Pause' key on the unit to set the change.
5.) Press the 'Stop' key four times and then remove the battery or whatever is powering the unit. Turn it back on and enjoy!
For those of you in Europe, you now have a full equalizer, no restriction on volume, and Kanji/etc support. smile.gif North American unit owners can do the same for better language support.
A big thank you to Ishiiyoshi for supplying the service manual for this unit!
p.s. For information on how to get into service mode with first generation Hi-MD units, check this thread:
http://forums.minidisc.org/index.php?showtopic=7434
To remove the volume limitation on first generation Hi-MD units, check this thread: http://forums.minidisc.org/index.php?showtopic=8157
  • Replies 172
  • Created
  • Last Reply
Top Posters In This Topic
The RH10 is still rare in Europe but nice to know the hack is already there because using a RH10 with e.g. EX71's without the possibility to have a custum EQ is suicide for the soundquality!
Now I can go and buy a RH10 as soon as it is available without having to thing about the European version as a "downgraded" and not real Hi-Fi device.
Thanks a lot to you great people!
p.s. I soon will contact Sony NL and ask them who I can kick very hard for getting the custom EQ removed from the EU-model. That was about the stupidest thing they could think of. It had been better if they removed the remote at all or but in a NH-10WM. Those things are easy for a customer to upgrade but removing a nice function as a cutom EQ and only having 4 useless standard settings is real stupid. How do they dare to still call it a 6-band equalizer when there is nothing to equalize!
Do I sound pissed? I realy am!
you can buy it on canadian or american web site, it's nearly the same price as in europe (that's what i've done)
And then I have to buy another adapter, when I have something with warranty I have to return it to the US and when I'm lucky and the customs check the package I have to pay a lot extra. No thanks, I only buy European stuf.
The below text is beta - DO THIS AT YOUR OWN RISK
Here's how you remove this limitation:
3.) Press the 'Vol +'/'Vol -'key and set the value that is after "DistFL" to 24.
does this work on RH-910?? i have my RH-910 which does not have custom EQ as well.
another question: my RH-910 cannot play mp3 transferred using sonic stage, it shows the message "Cannot Play" when i'm trying to play it. how can i solve this problem? any firmware hack on this?
did this work on a european RH10??? I try this on my Euro-Model but nothing happend! I can't see any service mode... Please give me an hint!
maybe I missunderstand this message? did you realy get into the service mode at the RH10?
my model is canadian and it works, you must do it fast to work.
http://home.pichu64.net/discour128.mp3 you can try with this file, it worked for me (it's a legal file, so you can download it)
Edited by pichu64
You need to enter service mode exactly how I've described it. Please re-read and try again. wink.gif
yeah i saw hex number below the 0113 item number. and when i press vol+ the last digit of the hex string incremented. but i never seen "DistFL" on my MD screen.
hi kurisu, my RH-910 is asia version and i believe that it's originally doesn't support mp3 playback. do u know the way to hack it?
Thanks for your beeing a helping hand... but..
I switch the hold buttom - hold down "menue"
FF FF RW RW FW RW FW RW - Pause key (the Jogwheel?) 2 times
- by holding down the menue I press vol +
- I do this fast and slow... maybe 20 times.
at the display you can only read "Hold"
what I do wrong?
Yes, I have a real (fxxxing) RH10 Euro Model.
what I do wrong?
you are wrong. the pause key is not jogwheel but the key beside REC.
here is the steps:
1. switch on ur MD (by pressing anykey)
2. slide on the hold key
3. hold down the menu key
4. press the key sequence : FF FF RW RW FW RW FW RW || || (|| is pause key)
5. now release all keys.
cool kurisu, it works on my RH-910 also... thank you..
now i'm trying to figure out complete steps working on my RH-910
6. u will see the screen is blinking ( version and black background)
7. now press vol+ 1 time and u will see a word "manual" on screen
8. now press >>(fast forward) for 5 times and 0113 string will be displayed on screen, as the same time u will see the string below it is incrementing
9. when u press vol+ the last digit will be incremented by 1 opposite for vol-, so you have to change the last 2 digits to 24 by using vol+/- key. you should know hex number right!!
10. press || (Pause key) once
11. press stop key 4 times
12 remove ur batt.
Edited by erictioh84
@erictioh84 and @kurisu GREAT it's WORK!
I confoundet Pause with Stop. So I quote your last describe to our german minidiscforum - thanks a lot!!!
schnitt
NV
0111
ResAll CC
0112
Clock CC
0113
DistFL 24
0114
DistFH 80
0115
ClrVNV 00
0120
Laser
0121
Lrefpw 14
0122
WrPwx4 A9
0123
SettHM3 CC
0124
HMD3RH 36
0130
Temp
0131
SetTmp 19
0132
Dsptmp 25
0133
TmpOfs DC
0200
SET
0210
DiscPr
0211
NomiRP 2E
0212
NomiRT 1E
0213
NomiWP 8D
0214
NomiWT 28
0215
OptiRP 22
0216
OptiWP 69
0217
Adrs H 18
0218
Adrs L 14
0219
ResDrp CC
0220
AdjUID
0221
040706
0222
000000
0223
131253
0230
MD1Pr
0231
DscSel 01
0300
OTHER
0310
LED
0311
Ch0p H FF
0312
Ch0p L 3F
0313
Ch0p0F CC
0900
LINE
0910
MngFlg
0911
MngF1 00
0912
MngF2 00
0920
Other
0921
TsbSsb 00
these are the codes for my MD RH-910. can anyone compare and check whether any field is not same as yours? because mine one really cannot play back mp3 directly. whatever files i have tried on. so i would like to compare these code with yours to see what are the differents. who knows it might be the firmware's problem that i can easily fix it using modify the value..
erictioh84, did you try the mp3 file that i posted?
yeah, i have tried the mp3 that u posted on this thread. it's not working on my RH-910. i've found from a forum, they said asian version doesn't support DIRECT-MP3, so mine is asian version.
so anyone with RH-10 or RH-910 please compare your firmware code with mine, any different please let me know thanks.
.... sorry useless question....
I have RH10, and I too could not see 'DistFL' under 0113. However, I changed the last 2 digits of the sequence to 24 (whilst all the other digits were constantly changing), and exited the hack as per instructions.
I now have the full Equaliser selection (yes!), BUT I can hear no appreciable difference in volume when playing back, ie I still need the volume at 90%+.
Is it possible that only part of the hack has worked? Is there any way of actually confirming that output is now 5mw? And, final question, is there any reason why 'DistFL' did not appear anywhere on my machine?
Sorry for idiot questions, but 'hex numbers' means absolutely nothing to me!
And, by the way, thanks for the time and effort taken in working out this hack - it is much appreciated by us Europeans.
after u have changed it to 24, u try to to enter it again, u will find it DistFL already..
Kinda off topic but i REALLY dont get why in the hell would Sony bother to do this. Wont it be a whole damn lot easier to have it all turned on? The only reason i can think of is maybe Europe have some regulations on this. Else i dont see why Sony would bother to do this.
after u have changed it to 24, u try to to enter it again, u will find DistFL already..
Maybe the firmware version of RH910 and RH10 is obviously different. Just a guess. More profitable might be a comparison beteen a RH910 and an RH910JE
but as what kirusu said, his MD got DistFL this word, and mine got that too. in extra, the custom EQ hack on RH-10 is applicable to mine too. so i think that is a big possibility that RH-910's firmware is the same as RH-10 but just some hrestriction as been done in the firmware. just a guess... if anyone got free time help me check the firmware code whether same or not. just a checking, better than not right? this is the only way and only hopes for my MD.
I just entered service mode and successfully changed the value to 24. My entry was also on a changing hexadecimal number that ended in 22 I believe.(I meant to write it down) I had some trouble getting some poorly encoded mp3 files to play on my RH10, and manually encoded them to Atrac last night. I tried uploading an mp3 that I knew was a good encode just now, and it worked and played fine, so I know mp3 support is ok.
Edited by milomind
if i simply change any value, will it cause my MD unbootable or unstartable?? who can confirm it?
Should you deviate from the prescribed destination codes, your unit will likely not function. Of course, I can't confirm that. But to be on the safe side, use only prescribed destination codes given by the service manual.
actually what do u mean service manual? what i'm requesting is a manual with full explaination about which value to set and what are the meaning of every value of the MD. but i cant find it at first page of this thread
The procedure highlighted in the first post - changing destination codes, specifically to "24", is with the intent to enable European and North American models to attain functions such as Japanese/Chinese character support, full EQ selection and no volume restriction (especially for the European model). This procedure, “Destination setting” is quoted from the service manual itself. So, what you read in the first post is essentially part of the service manual.
To answer your query, the Service Manual does provide explanation to all abbreviation, codes, shematics and part numbers; and the adjustment value “24” represents the following destination: Hong Kong, Korean, Australian and Tourist model.
If you need further information just post accordingly and we will try and answer your query. However, I think the aim of the initial post is clear.
I found that in 0113 DistFL
if you set the last number 0,1,8,9
The language option include En,Fr,Deu,It,Es
set 2,3,a,b, there will be Jp,En(Japan Version default is 23)
set 4,5,c.d, Jp,En,Fr,Deu,It,Es,Chinese simplized,Chinese Traditional
set 6,7,e,f, Jp,En,Fr,Deu,It,Es
And there's some option that the 1st gereration himds don't have
1800 Info
1810 DistFL
1811 DistFL 23(same as 0113)
1812 DistFH 80(same as 0114)
1820 FirmF
1821 FirmFL 98
1822 FirmFH 80
1823 FValid 00
1830 HardF
1831 HardF0 61
1832 HardF1 E4
1833 HardF2 40
1834 HardF3 AE
1835 HValid 00
1840 Pwr F
1841 Pwr FL F1
1842 Pwr FH A0
1843 PValid 00
Mine is Japanese Version RH10
And I must apologize for my English......I'm not a native English speaker....
If there's anything you don't understand I'll try to explain it....
Hope it's useful for you guys.....
