Kaineda77 Posted May 10, 2005 Report Share Posted May 10, 2005 (edited) Hi together,I have a collection of about 100 Md that I recorded analogue with my Sony RC-30 (really old). Now I thought of buying a new HD-Minidiscplayer and putting all my old Md on very few Hi-MD. How should I go about it? I would prefer to put them digitally on a pc and from there on the Hi-MDs but I lack the proper cable for the RC-30. Does anybody know which cable I might use? Or is it easiest to directly connect the two Md-Players?Thanks beforehand,Kai Edited May 10, 2005 by Kaineda77 Quote Link to comment Share on other sites More sharing options...
atrain Posted May 10, 2005 Report Share Posted May 10, 2005 you options as i see them arerc-30 -> pc* -> himdorrc-30 -> himdi'd go with option one although both are going to take some time & suffer some sound quality degredation. with both methods you can use the software to title & manage the songs on the discs. if you still have any of the cds or mp3s the music came on use them instead* into a recording software like audacity or soundforge then to sonicstage. Quote Link to comment Share on other sites More sharing options...
Kaineda77 Posted May 10, 2005 Author Report Share Posted May 10, 2005 Thanks a lot, so I guess there is no way to tranfer the music digitally/losless from a MD-Player to the PC? Quote Link to comment Share on other sites More sharing options...
atrain Posted May 10, 2005 Report Share Posted May 10, 2005 i'm sorry i can't find a reference to your model no. on the database here or via google. if your md player has an optical out & your soundcard has an optical in you can record it that way still using the software to record.current himd models will playback your old discs too. Quote Link to comment Share on other sites More sharing options...
MusicBringer Posted May 10, 2005 Report Share Posted May 10, 2005 Hello Kaineda77, like you I too have many many traditional minidiscs. However, although I considered transferring it all to several One Gig discs I have left it all as it was. I can play them ok on my new NH900, as well as my old Denon Deck.I thought the time and cost to do the transferring, plus the inevitable loss in sound quality was just not worth it. My efforts are now directed to making One Gig discs of New (to me) Music. Quote Link to comment Share on other sites More sharing options...
Kaineda77 Posted May 10, 2005 Author Report Share Posted May 10, 2005 Thanks for the bad news guys ;-), damn, and I thought we were living in the digital age Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted May 10, 2005 Report Share Posted May 10, 2005 Kaineda77 said: Thanks for the bad news guys ;-), damn, and I thought we were living in the digital age←well... now we are, but unfortunately it only began @ hi-md Quote Link to comment Share on other sites More sharing options...
Syrius Posted May 11, 2005 Report Share Posted May 11, 2005 I would suggest getting a MD deck with optical out, plugging that in to a Hi-MD unit that has input, (record in the flavor of your choice), and upload it from the HiMD to your PC. And then use Marcnet's Hi-MD renderer to convert to the format of your choice. Quote Link to comment Share on other sites More sharing options...
atrain Posted May 11, 2005 Report Share Posted May 11, 2005 Syrius said: I would suggest getting a MD deck with optical out, plugging that in to a Hi-MD unit that has input, (record in the flavor of your choice), and upload it from the HiMD to your PC. And then use Marcnet's Hi-MD renderer to convert to the format of your choice.←it'd still be easier to record md digi out to soundcard digi in.anyway kaineda is it deffo an RC-30? & does it have the optical out? Quote Link to comment Share on other sites More sharing options...
Kaineda77 Posted May 11, 2005 Author Report Share Posted May 11, 2005 Sorry, I remembered it wrong, its a Sony MZ-R30. It has just a normal line-out, but I dont think this should be of any importance, since, in case I get a Himd-Player, I can as well use the optical out of this, right? Quote Link to comment Share on other sites More sharing options...
A440 Posted May 11, 2005 Report Share Posted May 11, 2005 Hi-MDs have optical in, not optical out. If you record out of the headphone jack through your soundcard to your PC, with something like Audacity, then you are recording the analog signal from the headphone jack. If you do get a Hi-MD, you could use the TotalRecorder method:TotalRecorder records what goes into your soundcard before the computer plays it back, in real time. It's $11.95, well worth it. http://www.highcriteria.com/Put the old MD into the Hi-MD unit, hook up via USB. Use SonicStage to play back the old MD through your computer, and record it with TotalRecorder. Then use CDWave to split it automatically into separate tracks. http://www.milosoftware.com/cdwave/ Quote Link to comment Share on other sites More sharing options...
Kaineda77 Posted May 11, 2005 Author Report Share Posted May 11, 2005 I thought Hi-MD could be used to store data and stuff as well, how can it then not have an optical out? I am probably getting something seriously wrong here.... Quote Link to comment Share on other sites More sharing options...
A440 Posted May 11, 2005 Report Share Posted May 11, 2005 It has a USB port that connects it as a data storage device. Optical out is different--it's like a digital version of the headphone-out jack. Quote Link to comment Share on other sites More sharing options...
Syrius Posted May 12, 2005 Report Share Posted May 12, 2005 A440 said: Hi-MDs have optical in, not optical out. If you record out of the headphone jack through your soundcard to your PC, with something like Audacity, then you are recording the analog signal from the headphone jack. If you do get a Hi-MD, you could use the TotalRecorder method:TotalRecorder records what goes into your soundcard before the computer plays it back, in real time. It's $11.95, well worth it. http://www.highcriteria.com/Put the old MD into the Hi-MD unit, hook up via USB. Use SonicStage to play back the old MD through your computer, and record it with TotalRecorder. Then use CDWave to split it automatically into separate tracks. http://www.milosoftware.com/cdwave/←Sorry, but that won't work. SonicStage will not play the music through the computer if it's a regular disc recorded on true SP or NetMD mode. The sound will be heard through the Hi-MD headphone out. Quote Link to comment Share on other sites More sharing options...
