Sony D-VM1 DVD WALKMAN
lxrichbirdxl
Just another discontinue Sony product.
Well, I remember see this in a promotion booklet that Sony sent to my house, back in 2002.
This babe has got the ability to play many DVD formats while still in around the standard size of a portable CD player!
...and it has a seperate 3.5"LCD to view the content if you play DVD. Enough teasing, but I'll try to find out more about this player.
Anyone here has any info on it?
Thanks! :ol_biggrin:
12 answers to this question
Yes, I sure remember this nifty little product. I believe it was a 2001 release. If you like, I can update this thread later with further description/specification of the unit.
Update: The D-VM1's description/specifications as per requested.
The Sony D-VM1 WALKMAN was first announced for retail sale on September 27, 2001. The D-VM1 can playback DVD Video; features: DVD-R, DVD-RW, VCD, and CD(CD-R/CD-RW) playback support, Virtual Surround Sound for Headphones and Speakers, a Built-in Remote Control, and Up to 4 Hours of Playback with the supplied Rechargeable Battery. Additional features include Dolby Digital™, Dolby® Surround Sound and DTS® (Optical Digital Out Only) Audio Formats.
post-6287-1111734271_thumb.jpg post-6287-1111734334_thumb.jpg HIMD_Xtract_0.05b.zip
post-6287-1111777639_thumb.jpg 2005_03_25_MD_Labels_lowres.pdf post-3514-1111818209_thumb.jpg
Specifications
System
Device type: CD/DVD player
Signal format:
Monitor module - JEITA standard and NTSC/PAL color system;
AV output - Video CD: JEITA standard and NTSC color system | DVD: Color system
Horizontal resolution: 500 lines
LCD Screen
- 3.5” TFT monitor
- 165g
Audio
Audio frequency characteristic:
DVD (PCM 96kHz): 4hz - 44kHz (±1 dB)
DVD (PCM 48kHz): 4hz - 22kHz (±1 dB)
CD: 4hz - 20kHz (±1 dB)
Audio Signal-to-noise ratio: 110dB (Audio Out jack only)
Audio Harmonic Distortion: 0.005%
Audio Dynamic Range: DVD: 103dB | CD: 99dB
Audio Wow and flutter: less than detected value (±0.001% W PEAK)
Maximum power output (at DC): 25 mW + 25 mW (16 ohms)
AV Output Adaptor
Output Video Terminal
- Video Out: Mini jack
- S Video Out: 4-pin mini DIN
Output Audio Terminal
- Optical Out: Mini jack (Dolby digital, DTS, linear PCM)
- Audio Out: Mini jack
- Headphone Out: Mini jack
General
Power requirements: 100 to 240V AC, 50/60Hz
Power consumption: 6 W
Battery life: 4 hrs (when the cover of the monitor unit is open); 5 hrs (when the cover of the monitor unit is closed)
Size: 150.2 × 31.8 × 167.7mm (w/h/d)
Mass: 323g (player only); 571g (with rechargeable battery)
  lxrichbirdxl said:
What exactly is that removable cover like thing which that player is inserted in?
That is its LIP-30 lithium ion rechargeable battery.
  lxrichbirdxl said:
Can it play DTS when listening through heaphone?
I don't believe you can. DTS only works with Optical Digital Out. If there is any consolation, the D-VM1 offers the two sound modes to enjoy your DVD with your headphone via Virtual Surround - 1) V-SUR1 for inner-ear headphones and 2) V-SUR2 for open-air headphone such as the MDR-F1. Option 2 allows Dolby Digital and Dolby Digital 5.1-channel.
this wasnt a dvd 'walkman' but it was a dvd player and cd writer i think, it was basically a portable cd/dvd rom drive, that looked like a cd walkman, It featured the rm-mc11el. ring any bells?
:ol_fatpleased: here it is: model: MPD-AP20U
it had a usb connector for connecting to a pc, but worked as an mp3 player etc:
Edited by mercury_in_flames
Yes, I do remember this unit. Damage did mentioned he was going to write a little review about it. So, stay tuned. :ol_smile:
Mmm, I remember that unit. I never got around to getting it though, so I'm afraid it'll remain "undiscovered."
It looks very interesting though, and it has the ability to play WAV and MP3 files off of a burned DVD... To bad there won't be any follow ups by anyone in this regard however.
Oh yes! I forgot about this (old) thing (with poor battery life). It was the only walkman-sized device to play MP3s of a DVD-R! I wonder how much they want for it now and if it's even worth getting. How's navigation of directories on this?
  Stuge said:
One & only "DVD" walkman ever released by sony till date.
=Definately ,I would like see further description/specification of D-VM1.
True in the very strict literal sense of the term "DVD Walkman" but you guys are forgetting 1998's "DVD Discman", the very first DVD Discman by Sony, the PBD-V30...
http://www.movie-mania.dk/Hardware/Sony/PBDV30.htm
http://www.homecinemachoice.com/reviews/hc...SonyPBD-V30.php
Since Sony stopped using the Discman name in favour of "CD [or DVD in this case] Walkman" and since the PBD-V30 is the same product type, there have been more than one of these made by Sony :P
