Surrender to Hi-SP
valurot
I've been fooling around with my U.S. RH10, and after much experientation with custom EQ settings and varying compression rates, I've resigned myself to the unhappy fact that Hi-LP's sound quality isn't sufficient. And, boy, how I've tried to convince myself otherwise!
So here's what I'm getting at:
1. Is Hi-MD *actually* a more worthwhile format than MDLP? 80 minute discs are at least 6 times cheaper than the 1 GB discs, and 6xLP2 > 1xHi-SP in terms of storage volume. So, dollar for dollar, LP2 is a far better bargain.
2. Can Hi-MD units be hacked for a compression rate somewhere between Hi-LP and Hi-SP?
3. What are your opinions on the the sound qualiy of the Hi-MD compression rates? A friend of mine (with an NH1) questions my sanity for my dissatisfaction with Hi-LP.
Overall, I realize I'll need to buy 4x as many Hi-MD discs now to archive my music collection (CD/vinyl). Ugh!
1) you can transfer LP2 to Hi-md formatted disks using Sonicstage. There you go!!!
2) The compression "somewhere between" Hi-LP and SP is, infact, LP2
3) LP2 sounds, to most, better than Hi-LP, but it depends also on the type of music you listen to.
Cheers
1. yes, as you can't compare LP2 to Hi-SP IMHO, Hi-SP><SP would be better and you'd get much more on a disc (even on a reformatted 80min) in Hi-SP than in SP so dollar for dollar Hi-MD is a better bargain, as I like quality over quantity (otherwise I'd just buy a 20gig i-puddle or something)
2. you can still transfer atrac3 (132kbps) and other bitrates through SS (just check your software) without any hacks...have you even read the user manual or just played with it?
3. I started out with atrac3 (132kbps) but after buying some better headphones and ripping a couple of CD's in Hi-SP and noticing the difference I now only use Hi-SP for listening and Hi-SP or PCM for recording
4. why use Hi-MD as archive media? IMHO they are way to expensive for that... just encode into FLAC and write to DVDR or even CDR, they are really cheap (compared to Hi-MDiscs and if you copy them each five-2-ten years, there's only a very little chance the media will have degraded, aspecially if you stock them right)
5. if you want to listen cheap (or just because you have to as you can't find any Hi-MDiscs around any more tongue.gif ) buy a lot of cheap 80min-discs and reformat them as Hi-MD
greetings, Volta
You can use LP2 with HI-MDs? When I use Simple Burner, I only receive 4 options: 48k, Hi-LP, Hi-SP, and PCM... Can I rip CD's to MD using SonicStage?
Hm.. I'm intrigued.
Hm.. I'm intrigued.
as I said read the help/manuals...you can't rip CD's directly to MD with SS...but rip to library, transfer, delete files from library
Hm.. I'm intrigued.
Depends on what unit you have --on 1st gen units you need to set Disc Mode (in the Menu) to MD mode (default is HI-MD) then SS will give you the SP/LP2/LP4 options.
I don't know about 2nd Gen units --my Hi-MD unit is a NH1.
As far as 1GB Hi-MD discs are concerned --again you pays your money and takes your choice --but as you can get 80 Min discs for less than 1 € each (around 60p or approx 1 USD) I'd go for a pack of 200 80 Min discs unless you really need the 1GB disks.
You can reformat to HI-MD if and when you need to.
Cheers
-K
Cheers
-K
Edited by 1kyle
  valurot said:
Volta, what's this FLAC you're talking about? And can it be used for archiving vinyl? I just figured that MD would be the easiest way to archive vinyl... No?
It is a lossless compression format. It is free and there are plugins for WinAmp. Like Volta, I use it too for archiving purposes.
http://flac.sourceforge.net/
Yes. Especially considering the fact that you can more HiSP tracks on a HiMD-formatted MD80 than you can LP2 tracks on an MDLP mode disc, with much higher quality.
  Quote
No.
  Quote
My opinion of the ATRAC/3/plus rates, in order of preference:
1. PCM, for obvious reasons [i rarely use it, though, for portable listening]
2. ATRAC SP, which has no support via USB
3. HiSP, which I use extensively and have no real qualms with the quality of [at least with 1st-gen compressed material]
4. LP2, which is okay for some things, but I generally consider SS and SB's LP2 encoding to be absolute crap
5. HiLP 64kbps, which is fine for voice recordings but I wouldn't use for anything else. It's simply not good enough for my ears and taste.
Your mileage may vary. Many people are actually happy using HiLP, though I can't actually understand how.
To be honest, I use Hi-LP a bit. I have most of my music on a few 1GB discs and take them away with me etc when I want my whole collection. I don't mind the loss in quality in these circumstances as I'm just listening on my portable and its ok, not great, but ok.
Day to day at home though, I use HI-SP as of course it sounds better. 1GB discs are not as expensive or hard to come by in the UK as they were so I don't have a problem with the way I do it at the mo.
just check corien's link (it explains FLAC and offers the downloads you need)...
  Quote
just a little clarification...
1. every format CAN be used for archiving, but all depends on your needs for quality! if you don't care about quality, use 64kbps MP3 or Hi-LP as it takes up less space, but it won't sound like music anymore probably tongue.gif
- wav/PCM are 'the best', as it doesn't compress anything and won't diminish sound quality, but they take up alot of space
- FLAC is 'even better', as it is a lossless compression (which means no quality loss but less space required) but there are (to my knowedge) no recorders (and perhaps even no PC-software) that can record directly into the FLAC-format so first record in wav/PCM (best quality) then encode as FLAC
2. is MD the best to archive vinyl (part I: recording)
as you should record your vinyls to wav/PCM, you should use the option that gives the best quality (but I don't really know much about this, I never archived any vinyl):
- Hi-MD in PCM -> would be good I guess, but you have to upload
- directly in wav on PC (audacity or something)-> all depends on the quality of your the audio-equipment of your PC (soundcard,...)
3. is MD the best to archive vinyl (part II: storing)
- MD (and probably Hi-MD too) is a durable but sometimes expensive medium... you could use it to archive, but then I would drop FLAC files on them as data (doesn't require SS and allows the FLAC quality@less space bonus) and not as playable music (no FLAC-support!)
- CDR and DVDR are very cheap nowadays, I would say, just burn all your FLACS to CDR/DVDR, store them well (as real archive material) and copy them once every (help me out here DEX?) five-2-fifteen years (at least before the media starts to degrade)
that is at least my idea... greetings, Volta
PS:
you can't set a 1gb disc to MD-mode (only normal discs) but Hi-MD discs (1gb and reformatted old ones) will take atrac3@132kbps and other rates...just check your player's user manual: page 101 'recording times for all formats/discs' or something in my NH900's manual...pages added in attachment)
[attachmentid=397]
Edited by The Low Volta
[attachmentid=397]
Sorry I meant ONLY if you've got 60/74/80 min disks in the unit.
In this case at least on the NH1 if the disks are NEW it will default to HI-MD mode --you have to set the player to MD mode (for SS taransfer in SP/LP2/LP4).
If the disks have already been used then it should sense MD mode.
Sorry for the confusion.
Flac lossless compression seems fine also (although extra steps in your workflow when you need to make your music 'Playable' ) but probably good for archiving.
I keep 99% of my stuff in ATRAC3+ @ 256kbs --as I haven't got anything to play the music on that I'd notice an improvement over HI-SP on anything else .
Lp2 also doesn't actually sound too bad if the original source was recorded properly in the first place.
I agree calling MP3 and Music in the same sentence is a bit of a misnomer.
Why does the cruddiest stuff always seem to get to be the most popular
Betamax Vs VHS
OS/2 Vs Windows
MP3 vs any other format you could name.
Cheers
-K
Edited by 1kyle
I use FLAC on a daily basis. I use it so often, in fact, that I have made a "droplet" on my desktop for the encoder with my preferred settings [which I find more convenient than using a frontend].
And yes, I *listen* to FLAC files on a daily basis, not just use it for archival.
Try out Foobar2000 .. I use it for MP3, WAV, FLAC, APE, MPC, OGG, AC3, and DTS, all on a regular basis. [Daily for all but MPC, OGG, and AC3, which I use less often than any of the others.]
The only disadvantage I find with lossless-packed formats [like Monkey's Audio/APE, FLAC, and Shorten] is that they have the be converted back to PCM for editing.
I too actually listen to FLACs on a daily basis, and don't use FLAC only for storing purposes. For listening I use WinAmp with its FLAC plugin - for encoding I use dBPowerAmp with its FLAC codec.
FLAC format is peculiar in adopting an asymmetric encode-decode algorithm, so that decoding and rendering into a WAV file is superfast. The price to pay is that the encoding process is quite time consuming.
I'm sorry 1kyle, but you're wrong. Please read the pages I uploaded from the user manual: through SS you can use LP2/LP4 (but not called that, just Atrac3/132kbps and Atrac3/66kbps) on Hi-MD formatted discs (1gb and reformatted or new 80min's)... Only SP is limited to MD-mode.
haha, I was actually mainly referring to the rediculously low bitrate one could use if one doesn't care about quality... I wouldn't dare stirring up the MP3><atrac-discussion again so I edited the above statement laugh.gif (added "or Hi-LP")
My remark was only concerning Hi-MD...I didn't mean that FLAC is for storage only and you can't listen directly to FLAC-encoded files tongue.gif (I use winamp as well)... I just meant that if you put a FLAC-file on (Hi-)MD, it will only be possible as data and not as a portably playable soundfile
so just to be clear:
- for recording I use Hi-SP & PCM
- for portable listening I use Hi-SP
- for PC listening I use FLAC
- for storage & archiving I use FLAC (written on CDR's)
greetings, Volta
Thank you all for your input, advice, insights, etc... I'm thinking of the following process for vinyl archival:
1. Vinyl --> Hi-MD @ PCM
2. PCM --> wav
3. wav --> FLAC
4. FLAC --> CD-R
I've got to go read up on FLAC now. Thanks again!
2. PCM --> wav
3. wav --> FLAC
4. FLAC --> CD-R
That's brilliant. I archive my vinyl collection digitally as well - Vinyl to WAV format via SonicStage Mastering Studio. Please let us know how it goes with your project.
I hope you don't store it in wav?
I also store my archive in FLAC, would be a wonderful world if I could play it back from MD too smile.gif
Why not
1) Vinyl ===> WAV direct using Total Recorder / other recording program
2) WAV====> FLAC
3) FLAC ====>CD-R
Simultaneously Import the WAV music file into your Library with SS ATRAC3+ @ 256kbs
(Doing this simultaneously will speed up your Workflow).
Upload to MD from the library via SS so you've got your vinyl on MD.
After you've processed the original WAV just delete it to recover your disk space.
Your Vinyl record is unlikely to be as much as a CD (approx 800MB WAV file for a 70 min CD recorded at 44,100 16 bit)
Cheers
-K
Edited by 1kyle
  1kyle said:
Why not
2) WAV====> FLAC
3) FLAC ====>CD-R
yes that definitely is an option (and even a faster one), but it all depends on what soundcard (quality) and input-options your PC has (if it is a mic-in or line-in, ...)
if you're not sure about the quality and sorts of your setup, just record one demanding test-track in both ways (Hi-MD->PC and PC directly) and compare the sound quality afterwards...
  Quote
Simultaneously Import the WAV music file into your Library with SS  ATRAC3+ @ 256kbs (Doing this simultaneously will speed up your Workflow).
but not really simultaneously I would say because letting SS work simultaneously with any other program at all increases the chance that SS (a processor-hungry dragon of a program) will make mistakes in converting or freeze your PC (in which case it would ruin two processes)...
so just take it one step at a time:
save as wav-> encode to flac -> archive (on CDR) -> import wav as Hi-SP into SS. library -> delete wav
Volta
Heh... our very own #1 FLAC fanboy. Sorry to disappoint you, but I do store them in WAV format. I have no immediate need to adopt FLAC as yet; in addition, HDD is so affordable nowadays.
Alright... back to the topic.
Comparisons between a £17 Fuji MP3 player & Hi-MD (Hi-LP) NH700 (European). "Unique" EQ setting. Cheap in-ear headphones (£5 Maplins)
Native mp3 file on Fuji, mp3 burned to CD (WAV) and transfered to Hi-MD.
Test environment - office (background noise - computers etc)
Hi-LP sounds 'lighter' on treble than the mp3 although bass is deeper. Percussions are particularly more noticable.
Vocals and sounds such as crowds clapping sound 'muffled' compared to mp3.
Artifacting can sometimes be more obvious with Hi-LP. However there is a greater sense of sound stage. There are some aspects of the music that I can hear in Hi-LP, but can't on the mp3. blink.gif
Mp3 sounds clear, but somewhat lifeless. Hi-LP has a much 'warmer' sound.
In conclusion, I wouldn't recommed either for 'serious' listening, however for music to play in the office at work, or jogging etc. Hi-LP comes very close to mp3.
Then theres the benefit of the HUGE amount of storage available on a Hi-LP recorded MD than a fixed memory mp3. So Hi-LP marginally wins. happy.gif
2. PCM --> wav
3. wav --> FLAC
4. FLAC --> CD-R
When copying my vinyl I go straight to the computer in 24/88.2. I have yet to use my HiMD [after nearly a year] for copying -any- audio from an analogue line source for other than test purposes. I always do it on the puter, then send it to HiMD. I prefer to edit in the highest resolution format I have available.
My FLACdrop also uses the --lax option to encode 24-bit audio; the end result is that you can usually get roughly an entire CD's length of 24-bit audio onto a single CD-R [though I use DVD-R for almost everything now].
  dex Otaku said:
When copying my vinyl I go straight to the computer in 24/88.2. I prefer to edit in the highest resolution format I have available.
that seems logical to do, but your PC audio setup is probably of high enough quality to make clean/clear recordings... I wouldn't even try that with my shoddy portable laugh.gif
Volta
PS: @ MDGB2... interesting test, but what is it doing here? dry.gif
The original topic post about the quality of Hi-LP Vs other compression rates.
Edited by MDGB2
One of the main advantages of FLAC over wav is not only the saved discs space, but also the native support for tags. I couldn't live without tags to maintain a transparent music backup database.
ehm..."Hi-SP vs. Hi-LP" as in the title yes and other atrac versions/bitrates also 'cause of the question for something between Hi-SP and Hi-LP and comparison to LP2...but I never saw anyone (especially not the topic-starter) mention MP3 before... therefore my surprise when your test popped up without any explanation
Volta
Volta
Althouth my test did establish that Hi-LP is pants compared to LP2.... laugh.gif
  • 2 months later...
Isn't Hi-LP "meant" to be "pants" compared to lp2?
Isn't the compression rate much closer to lp4, and hi-sp more like lp2 (in size and quality?)
Sorry, I never owned an MDLP unit - Jumped straight from an SP unit to my beloved RH10, so I'm going from data on documentation and impressions from software rather than years of experience with MDLP like a lot of the guys here wink.gif
Genghisbunny
Personally I never liked LP2 that much. For some albums it was ok, older rock stuff. But I notice artifacts in a lot of my favorite albums though. SP was noticeably superior to my ears so that I usually used SP. I've only had a HiMD a little while, but I find HiSP sufficent for portable use. In a direct comparision yes PCM is better, but you'd need decent earphones and a quiet enviroment to really notice it. For me HiSP is fine my music sounds good in HiSP. But I didn't like anything I encoded in HiLP. That said I intend using the HiMD primarly for recording. Though I do find myself using it as a portable when my Mp3 player is out of charge.
  genghisbunny said:
Thanks for the info Sparky.  I think I'm glad I skipped the MDLP generation and the NetMD generation as people seem to bitch about them endlessly.
Then again, people love to bitch.
The only reason I used LP2 was to put a double album on a MD. While NetMD & SS would have been a lot handier way of putting music on a MD, CD>>Optical>>SP sounded so good I didn't see the point of using LP2. For me SS>>HiSP sounds as good and the advantages and capacity of SS & HiSP are worth any minor difference between it and SP. Though if I had leagacy deck or car unit, I'd probably still be using SP aswell.
IMO 1Gb are ideal for collections of podcasts. I like building compendiums, so I have started a 1Gb disc of stuff from itconversations.com. I convert mp3's in "speech" quality of 64kbps to Hi-LP and they sound fine even though they are transcoded.
LP2 - I have to say that LP2 sounds excellent when the source is CD. I used LP2 heavily to transcode from mp3 128~192~256kbps (mainly tracks from ocremix.org) and found the quality for portable/car to be adequate. Now that I've got my 2nd Gen Hi-MD though, I feel like remastering all my old discs with the original mp3!
  • 3 weeks later...
  Quote
Ha ha ha. MP3 distortion would be a more accurate description. :lol:
  Quote
Betamax Vs VHS
OS/2 Vs Windows
What about Blu-Ray vs HD-DVD? That could be a good battle... What do you mean no-one cares?!
