How to get the most songs on a MD?
  • 3 weeks later...
Sorry if i forget to include MD mode equivs, or if i inadvertently apply the wrong MD mode analogy....
105 or 133 (ATRAC 3), which i guess is around MDLP2 (sorry, just getting used to MD once more, after a long long departure from it) is pretty much what NetMD users i know used a lot for 'fire and forget' multi-album storage.
Works pretty well for job like getting an 8 CD collection to one CD-R (for ATRAC CD purposes) without hitting silly low-rate levels.
Personally, at MD/NetMD levels, i'd go with the above advice that quality is more preferable to quantity.
For Hi-MD, the options are more open, the extra capacity of Hi-MD media kinda closes up the ATRAC-CD vs Net MD capacity difference (at a price of course), and if you play the encode each track to what works best for the track vs storage considerations (aka what you can low-compress, low-compress, what you want to be sharper and more authentic, go with higher levels and mix/match to suit needs).
With later MD, Net MD and Hi-MD (and likewise for the FP's and NW-H
s and ATRAC-CD) there is no hammer of damocles ready to whack you one on the head if you mix/match to suit needs.
After all, the object where quantity storage is the key, is making the best use of what you have.
If quality counts, and ferk the quantity, SP/LP modes are on the cards.. or Hi-MD's Hi-SP.
