MD Simple Burner Installation Only
lyceemoliere
simple burner stopped working on my computer so i uninstalled it. i have the original disc but its bundled with ss and i dont want to risk losing my library by using the disc as it looks like both install @ the same time.
I found the download listed above (by kurusu) on th "hosted site" but what actually downloaded was winzip not simple burner and i cant figure out what i would be buying for $29. It looks like it is not simple burner at alll.
Any ideas of places i can get just simple burner via download or ideas re using the disc bu t avapoiding downloading sonic stage?
Not quite sure what you refer to when you mention paying $29. Simply download the Simple Burner Stand-Alone installation from our own downloads section by following this link:
http://forums.minidisc.org/downloads/details.php?file=2
No need to uninstall Sonic Stage.
Edited by richyhu
simple burner 2 is very much present in the downloads section.
its a zip file that is opened by winzip.. extract and install.. how did you manage to download winzip from the downloads section?? screenshots would be tremendously educational...
cheers
If you are using the demo version of WinZip (to open the SBurner.zip file), you may have inadvertantly clicked on the purchase button.
A single-user license for WinZip is $29.
SimpleBurner is free.
There are a few decent freeware utilities akin to WinZip that you should be able to find on the
web.
EDIT: Is this what you were seeing?
[attachmentid=925]
Edited by raintheory
cheers
i followed the link above, then when i tried to download the program. it asked for lyceemoliere and my password so i typed it in. then, when tried to download, i get the winzip icon with md_simple_burner under it. If i try to click on the icon, i am aksed to buy what looks more like winzip than simple burner.
i went to the following:
which led to--->
http://forums.minidisc.org/downloads/files.php?cat=2
which led to---->
then i get a grey box that says
file name: MD_Simple_Burner_2E.zip
file type: winZip File
from: forums.minidisc.org and asks me to open/ save /cancel/ more info
if i open or save it i get the winzip icon with MD_simple_burner on it and if i click on that, it asks me to pay $29 or get a trial version .am attqching the icon that results
[attachmentid=927]
winzip_icon.doc
Edited by lyceemoliere
When you get to this point choose to save the file to your desktop for example.
[attachmentid=927]
This is fine. Double-click on the resulting icon, (if you don't have the full version of Winzip installed), press the button that says use evaluation version which should open up Winzip with all of the files listed inside. In Winzip choose Actions => Select All. Click on the extract button and enter a folder path for example "C:\SimpleBurnerTemp". Click the extract button. Close Winzip. Using Explorer navigate to C:\SimpleBurnerTemp. Double-click on the setup program and complete Simple Burner Install. When this has finshed you can delete both the C:\SimpleburnerTemp folder and the Winzip file you saved to your desktop.
