spy1983 Posted January 11, 2006 Report Share Posted January 11, 2006 (edited) I bought a MZ-NH 900 last week. After that i bought a sony mdr-828lp earphone today. I like the sound of my md but i am just trying to find best sound. I usually use surround studio mode i think it is the best in the modes. When i turn volume up to the end a distortion begins i think. Is there a best sound that i can catch with eq or is there any suggestions or which mode is better in your opinion? And is there a eq setting equal to Sony's Megabass? Which earphone is better for hi-md units?Thank you Edited January 11, 2006 by spy1983 Quote Link to comment Share on other sites More sharing options...
KrazyIvan Posted January 11, 2006 Report Share Posted January 11, 2006 I think your weakest link is going to be the earphones you are using. I have the 828's and they are definitely not much better than stock buds. If you are trying to get the best sound from the NH900 try some better earbuds. The earbuds I use are listed in my sig. I have been happy with both with the exception of fit on the Panasonics. They make my ears hurt. Beleive me, you will not have a hard time trying to adjust for bass on either set. They are both pretty bassy and I usually have to turn the bass down a bit. Quote Link to comment Share on other sites More sharing options...
alrose312 Posted January 11, 2006 Report Share Posted January 11, 2006 I use the Jazz setting with Senheisser 100s and I think the sound is amazing on my NH-900. I mostly listen to Indie Rock. Quote Link to comment Share on other sites More sharing options...
sebastianbf Posted January 12, 2006 Report Share Posted January 12, 2006 I always use custom eq. since all my music need diferent equalization because i hear many kinds of music. About the earphones: I'm using my nh900 with a pair of Stanton Dj pro 60 headphones. In my opinion , the best headphones for about 40 dollars. You get Sony Eggo's 77s specs for 40 dollars. Plus, they are portable. Quote Link to comment Share on other sites More sharing options...
smkranz Posted January 12, 2006 Report Share Posted January 12, 2006 Agreed that the Sennheiser PX100s sound terrific. I prefer customizing the eq. to a u-shape curve, a little lighter at the bass end than the treble since the PX100s are strong on bass. Only downside to them is that they are inefficient compared with other headphones/buds, i.e. they don't get as loud and they let in ambient noise if you are listening in a noisy environment.For that circumstance (like, a trip on the parents' bus to a marching band competition ), I like the Shure E3c with the yellow foamy buds. Sure (no pun intended) to tune out any ambient noise, including a yakkety Spousal Unit. The Shures are plenty loud but need as much bass as you can give 'em, so adjust the custom eq curve accordingly. Quote Link to comment Share on other sites More sharing options...
spy1983 Posted January 12, 2006 Author Report Share Posted January 12, 2006 Thank you for your all replies. I have the European version of MZ-NH900 i think its output power is 3mw+3mw i didnt understand why did they do something like that... The other versions have 5mw+5mw... Is there any way to increase the output?A custon eq or virtual surround mode which one is better do you think? When i adjust eq, because of the output power i think the volume is not that much. Quote Link to comment Share on other sites More sharing options...
Richard Posted January 12, 2006 Report Share Posted January 12, 2006 I always use custom eq. since all my music need diferent equalization because i hear many kinds of music. About the earphones: I'm using my nh900 with a pair of Stanton Dj pro 60 headphones. In my opinion , the best headphones for about 40 dollars. You get Sony Eggo's 77s specs for 40 dollars. Plus, they are portable. I agree with this I also use the Stanton Dj Pro 60's with my NH900 (and all my other MD units) they are the best value headphones I ever had. Superb sound with 3-28000hz freq. response means some fierce bass ;-) - they are very durable (have had mine over 2 years, they have been round the world and still in near perfect shape), portable.... Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted January 12, 2006 Report Share Posted January 12, 2006 Thank you for your all replies. I have the European version of MZ-NH900 i think its output power is 3mw+3mw i didnt understand why did they do something like that... The other versions have 5mw+5mw... Is there any way to increase the output?A custon eq or virtual surround mode which one is better do you think? When i adjust eq, because of the output power i think the volume is not that much.Go to this link for the NH900 volume hack. The reasons for the volume limitations in Europe are well documented, but essentially it's due to French/EU policy for preventing hearing loss/damage... Quote Link to comment Share on other sites More sharing options...
jonny mac Posted January 12, 2006 Report Share Posted January 12, 2006 It's not too hard to increase the output to 5mW. Also, if you're looking for Sony earbuds that aren't too expensive and have good bass then try the MDR-E931s. There's a thread over at the T-board about them.http://www.audiotstation.com/forum/showthr...zing+stock+buds Quote Link to comment Share on other sites More sharing options...
spy1983 Posted January 15, 2006 Author Report Share Posted January 15, 2006 When i change my unit from european version to another version, will anything else change other than the 5mw output power?Also can you please write do you use eq settings or virtual surround setting and which presets do you use or prefer?Thanks Quote Link to comment Share on other sites More sharing options...
