Volume Hack for MZ-RH10(B) Latest --Thanks
1kyle
Thanks to all --- the volume Hack works even for the latest RH10 -B
--the B is the latest version of the RH10. :rolleyes::rolleyes:
Use this link as it's more up to date than the original method.
http://forums.minidisc.org/index.php?showtopic=9752&st=15
I've now got Custom equalisation etc etc. and decent volume.
Anybody in London --you can get the Black one's with the very sexy Blue screens which blow any IPOD away even for looks in Tottenham Court Road (London's Electronic Shop capital --load of electronic shops) for around 165 GBP -- a bargain. Just get out of the tube at Tottenham Court Road station and walk up the street -- electronic shops on BOTH sides of the street --non EU visitors can get VAT back and shops will take €'s as well (Euros). Loads of Sony Blue 1GB minidiscs as well.
(Visitors from Paris / Brussels using the Eurostar train service to London -- easy walk from Waterloo -- or 5 Mins on the tube).
BTW the gumstick battery is the same as used in the earlier but also very sexy unit the MZ R90 (SP only) so if you've an old R90 then you can use the battery as a spare.
Thanks again to everyone on this board -- Volume hack and equalisation for R10 great.
Cheers
-K
Edited by 1kyle
Correct me if I'm wrong but I thought the "B" simply indicated the colour (in this case black).
You are right --but there is definitely a revision on this unit so it is part of a newer batch compared to the initial production.
Cheers
-K
  • 3 weeks later...
still don't work on my rh710 :( bought last week in london
  • 5 years later...
