Can any AA battery case be used with any model of minidisc?
rentabau
hiii,
i have an MZ-M10 minidisc and was wondering whether i can use the external battery case of MZ-NH900 to be paired with my MZ-M10. the thing is, i've lost my external battery case. and i found that this guy is selling the external battery case of his MZ-NH900. can i safely assume that this battery case can be used with my MZ-M10?sorry if this has been mentioned somewhere in this forum. i've searched the forum beforehand, but can't find any info. :D
hiii,
I think the MZ-M10 has a larger AA clip on case than the NH900. The NH900 uses the same battery case as the old MZ-N1.
hiii,
I don't think it would fit on your MZ-M10. The battery case for MZ-NH900 would probably only fit MZ-NH models. I have an MZ-RH10 and the battery case for this unit will work on all MZ-RH models. Try finding a battery case for MZ-M models, that's more likely to work for you. But I may be wrong, so anyone else is free to correct me.
thanks guys for your quick responses. too bad it can't fit with my MZ-M10. since MZ-M10 is like a twin to the MZ-RH910, can i use the battery case for the MZ-RH models instead?
To be honest, I don't know. I'm not familiar with the MZ-M models. Is it a Canadian or European model?
it's not actually MZ-M100. as far as i'm concerned, MZ-M100 has OLED screen..the same as MZ-RH10. buy my MZ-M10 does not have OLED screen. it's more like a twin to the MZ-RH910, i believe. correct me if i'm wrong. but anyway, thanks a lot guys for the responses. i guess i won't be buying the external battery case of the NH900 then. ;)
