danielbb90 Posted June 17, 2006 Report Share Posted June 17, 2006 (edited) When I try to upload from my MZ-NH1 in SSCP 4.0 it says its transfering for about 1 second and then refreshes the Minidisc' content list? And it hasn't uploaded!!!Does anyone know whats going on here?Thanks for your help!Danny Edited June 17, 2006 by danielbb90 Quote Link to comment Share on other sites More sharing options...
Richard Posted June 17, 2006 Report Share Posted June 17, 2006 Does the track you are trying to upload already exist in "My Library" - if so it won't upload it again. Quote Link to comment Share on other sites More sharing options...
danielbb90 Posted June 17, 2006 Author Report Share Posted June 17, 2006 My libary is compleatly empty! lol Quote Link to comment Share on other sites More sharing options...
Avrin Posted June 17, 2006 Report Share Posted June 17, 2006 (edited) I never saw a 1st generation HiMD unit in my life, but this looks like a driver (NETMD033.SYS - this one is actually used for both 1st and 2nd generation units) glitch. Try disconnecting the unit, restarting your computer (completely), and then connecting the unit again. Edited June 17, 2006 by Avrin Quote Link to comment Share on other sites More sharing options...
danielbb90 Posted June 17, 2006 Author Report Share Posted June 17, 2006 Tried restartin' that didn't work! Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted June 17, 2006 Report Share Posted June 17, 2006 you didn't record in a legacy format did you? (SP or LP2/4)this won't upload... try recording something (short) in HiSP, something in HiLP and something in PCM just for testing... Quote Link to comment Share on other sites More sharing options...
danielbb90 Posted June 17, 2006 Author Report Share Posted June 17, 2006 it was Hi-SP 64kbps... Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted June 17, 2006 Report Share Posted June 17, 2006 HiSP = 256kbps... I guess 64kbps = HiLP or somethingjust record something on another disc for testing (and try some different bitrates) and also check whether the write-protection tab (of the disc in question) is onwas it a recording or a transfered track? I dunno whether tracks transfered from PC (with SB or older versions of SS) are actually uploadable... check with a recorded track...if that uploads, it has something to do with the rights to the track(s) in question and no probs with the hardware/softwarehave you ever (with older versions etc) been able to upload (this or similar tracks)?have you thought about posting full system specs according to ther rules? Quote Link to comment Share on other sites More sharing options...
danielbb90 Posted June 17, 2006 Author Report Share Posted June 17, 2006 (edited) I have actually uploaded these tracks before on the same version SSCP, just that was before a format and now they won't upload... And it was a transfered track I have uploaded them on 2 computers, just temparly before now just fine...I'll try recordin' somethings later, when I get the time... Edited June 17, 2006 by danielbb90 Quote Link to comment Share on other sites More sharing options...
raintheory Posted June 18, 2006 Report Share Posted June 18, 2006 (edited) Look around in and near C:\Documents and Settings\All Users\SonicStage\Packages and see if the tracks are anywhere in or around there...Failing that the only other thing I could recommend would be a full uninstall/reinstall of SonicStage. Although if you are able to upload other recordings (from other discs) then it may be an issue with the disc itself... Do you have any problems playing the track or just in uploading?EDIT: Just for kicks you could try renaming the track and see if it will upload after that. lol, never know. Edited June 18, 2006 by raintheory Quote Link to comment Share on other sites More sharing options...
danielbb90 Posted June 19, 2006 Author Report Share Posted June 19, 2006 I came up with a solution...Just it don't solve the problem, as I said I transfered these files to 2 computers before now, well 1 of those has been formated so I'm trying to get them back on it and I did a backup on the other one! I got the files just this still dousn't solve the uploadiin' proplem, but atleast I can use the files! thanks for your help,and yes, I tryed re-installing SS that didn't work! Thanks for all your help! Quote Link to comment Share on other sites More sharing options...
Avrin Posted June 19, 2006 Report Share Posted June 19, 2006 (edited) SS40 does have problems uploading. Various ones. Mostly serious. Legacy codecrap still plays its part...Try uploading just a few of your files. Such as a single group. Edited June 19, 2006 by Avrin Quote Link to comment Share on other sites More sharing options...
danielbb90 Posted June 19, 2006 Author Report Share Posted June 19, 2006 Avrin said: SS40 does have problems uploading. Various ones. Mostly serious. Legacy codecrap still plays its part...Try uploading just a few of you files. Such as a single group.lol tried, and single files too... Quote Link to comment Share on other sites More sharing options...
