Sparda Posted September 24, 2006 Report Share Posted September 24, 2006 These really are pathetic.... They sound worse then the earbuds that came with my RH1. I would continue to use the stock ones if they didn't chafe my ear, they are oversized. So i bought some canal phones. One question should i return these or should i keep them and hope burn in will make them sound better? To put it bluntly they lack power, there is no oomphh behind these.... I am greatly dissapointed... Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted September 24, 2006 Report Share Posted September 24, 2006 if you want oomph and you want painless ears... I'd really recommend the Sennheiser PX100 (very light on your ears and they sound very strong/full and even a tad bass heavy)... but these are not earbud or thelike of course Quote Link to comment Share on other sites More sharing options...
Richard Posted September 24, 2006 Report Share Posted September 24, 2006 The EX81's I had were not too bad on SQ - certainly a lot better than the EX71's (which is not saying much I know), but they suffered from the same poor build quality and lasted just a couple of months before the sound to the left channel died completely. Quote Link to comment Share on other sites More sharing options...
Sparda Posted September 28, 2006 Author Report Share Posted September 28, 2006 so would you suggest i keep them or let them go? Quote Link to comment Share on other sites More sharing options...
sector001 Posted September 28, 2006 Report Share Posted September 28, 2006 so would you suggest i keep them or let them go?that's a question only u can answer yerself. if you're not happy with them, then return them or sell them. i wasn't happy with the ex71's so i sold them off. as simple as that..... Quote Link to comment Share on other sites More sharing options...
