hi-md vs ipod
insch
I have used a MZ-RH10 for some time but I am hugely frustrated at the lack of Mac upload. I have no desire to buy a PC to rectify this but may look at Virtual PC. I am now considering getting an iPod with a mic - possibly the griffin iTalk Pro http://www.griffintechnology.com/products/italkpro/ but wondered if anyone had tried it and compared it with Hi-MD? It works at 44.1/16 bit so there's one comparison - it apparently sounds pretty good, especially if you connect an external mic to the iTalk housing whcih you can do (cuts out machine noise). I want to do environmental/atmospheric recordings for use in pieces of music and I want as good quality as possible at this very portable size.
I know there is a newer Hi-MD with the Mac upload option but I'm kind of sick of Sony and what seems like their anti-Mac policy.
Thoughts greatly apprecitated.
thanks
This is a little off-topic, but I do not think that SONY or anyone else has an "anti-Mac" policy. The truth is that Mac is a tiny section of the user base, < 5% and while its user base is growing, its market share is shrinking or barely staying the same. So why spend the time and effort for so few users? It is pretty simple.
I would go with the RH1 which is Mac compatible and a damned fine machine. YMMV B)
You might want to look at some reviews of the Griffin iTalk, like this one:
http://www.macworld.com/2004/08/reviews/ipodvoicerecorders/
the summary:
Griffin Technology iTalk iPod Voice Recorder 3.5 mice
Pros: Very good recording quality; audio-in/audio-out jack on unit; great value.
Cons: Slight voice distortions in sound quality; no file-format options for recordings.
If voice is distorting, then I can only imagine what happens with music. Ipods are made for playback and will grudgingly accept recording inputs. MDs are made for recording and have recordist-friendly features like level meter and level control, track marking, line-in or mic-in capability, etc.
Environmental recording is going to require a sensitive mic, and you are going to have to figure out a way to minimize machine noise. It's possible that neither an iPod nor a MD unit will be quiet enough for you, so you might also a consider a flash recorder like the Edirol R09 if absolutely silent operation is important to you.
What sort of Mac do you have: PowerPC or Intel? For the latter you should certainly go for Parallels as a virtual machine..
Edited by imkidd57
thanks everyone. I've now done a bit more research and it appears that there is no level control available for the iTalk iPod set-up even though they say 'adjustable gain settings give you control over the volume' on Griffin's site - that just means you have a high + low switchable setting. That's not good enough for me. I like the neatness of the iPod set-up but it doesn't appear that I'm going to get he quality I need. I'm prepared to sacrifice some sound quality for size though - I need a small unit and md works well for that.
all the best
I have a G5 by the way
