How to Edit Songs on Sonic Stage?
woofcyn
Top left corner of SS goto edit you'll have a divide command in the list. Start the track playing find the place you want to cut it at, pause it there. Use the divide command. You can then playback the resulting track if you don't like the results use the combine command and you can put the two back together and try again. POE
