Changing the Bitrate on tracks in Sonic stage
GQ Smooth
Please be more specific, what exactly are you trying to achieve?
If you want to have CD ripped lossy tracks in a different bitrate, it is recommended to re-rip them. Transcoding of lossy files, if possible, will give inferior quality. Losslessly compressed files are a good basis for conversion.
it will be transcoding from one lossy format to another and that means SQ-loss, unless you have them stored in a lossless format right now (WAV/PCM or Atrac lossless, in the latter case, you still need to go Atrac lossless -> wav -> new bitrate to keep SQ as otherwise the lossy part will be used for the conversion anyway)
sorry to say this, but you'll probably have to re-rip or live with the SQ-loss
