MZ-RH1 should be replaced
fstg
When you push a bit the Eject button, the unit resets to the first track. This means you cannot put the unit in your pocket when it is not in use. Why? Because every time you make a certain movement, whenever you touch the Eject button the unit reset's, but worst, since it drains the battery.
Sony should be aware of this design glitch and make the needed correction.
Somewhere on the forums is a report (with pictures) from some brave person who took their RH1 apart and replaced the eject button with a home-made but very professional one which doesn't project nearly as much.
I'm not that brave (or knowledgeable), so as a temporary fix I've glued a small strip of black leather beside the eject button, and that has more-or-less eliminated those annoying resets. Admittedly it doesn't look great, but I'm usually the only one who sees it, and I'm prepared to put up with it if it cures the problem.
