Problem with my MZ-R91 MiniDisc
fahrrad
Good day!
I would be very thankful if someone could help me with following:
i have some problems with my Sony mz-r91. When I open it, inside, on the uppersurface there is some kind of cap with a small thin metal plate and under it - some chip.
This plate is curved a bit, so it juts out. And when I insert a disc - it could be some wrong positions of it I don't know. I guess that the cap goes up and back and opens the chip.
Could it be a reason why the minidisc doesn't play properly? (it takes a long time to read the disc with some noise but finally it just gives up)
Thanks a lot in advance!
all the best,
alex
  fahrrad said:
Good day!
all the best,
alex
Are you aware of the unit being dropped or sat on , or hit somehow recently?
No, not what I remember.
Anyway, something should have happend to it, because the cap is being curved. I travel a lot, but always try to handle my recorder with care.
It's working partly, even recording, but the problem is with reading/playing only. I saw this cap was curved only yesterday and tried to insert discs in two different ways - with a cap closed and open, but the result was the same.
What do you think?
thanks
What do you think?
thanks
By "Curved " I thik you mean "bent" , and as for "cap " I am not sure what you mean post a picture if you can.
Yeah, "bent" is surely a better word. Sorry, I am not so good at all these termsб so "cap" is still cap.
I will attach a photo of it soon, so many thanks if you could find couple of minutes to help me.
This -was- the magnetic recording head. Don't insert any more MDs into the unit, they might get damaged / scratched / randomly erased. It's not easy or inexpensive to repair, so your best bet would be a replacement unit - a Hi-MD if you can afford it, or one of the older (used) models if you can't.
thanks a lot!
so you think there is no reason to try fixing it? actually it still plays some mds but not so good.
