Traksiris Posted April 7, 2007 Report Share Posted April 7, 2007 (edited) Hello, today I've bought a HiMD compared to the ipod beater (Sony NW-HD1, NW-HD5 these have static noises) this is even better... but the dissapointment is for not displaying the Japanese and Korean characters, since this is a quite new device compared with the HDD it shoul'd "do" Japanese and Korean and also the origin was JapaneseDid I do something wrong?To get Japanese I've used applocale Edited April 11, 2007 by Ishiyoshi Quote Link to comment Share on other sites More sharing options...
Strungup Posted April 7, 2007 Report Share Posted April 7, 2007 Hello, today I've bought a HiMD compared to the ipod beater (Sony NW-HD1, NW-HD5 these have static noises) this is even better... but the dissapointment is for not displaying the Japanese and Korean characters, since this is a quite new device compared with the HDD it shoul'd "do" Japanese and Korean and also the origin was JapaneseDid I do something wrong?To get Japanese I've used applocaleWhat Remote are you using ? I have a Japanese RH1 , and get Both Romaji and Kana , I have to scroll quite a way to get to it , but its there, I will check with both remotes and see, I have the 40elk with the scroll wheel , and REALLY like it it . Quote Link to comment Share on other sites More sharing options...
Traksiris Posted April 8, 2007 Author Report Share Posted April 8, 2007 What Remote are you using ? I have a Japanese RH1 , and get Both Romaji and Kana , I have to scroll quite a way to get to it , but its there, I will check with both remotes and see, I have the 40elk with the scroll wheel , and REALLY like it it .I have a european model which comes with a RM-MC38EL. I wan't to buy a 35elk/40elk but when I google for it I'll only get all those crappy ebay things, also I want to pay when on arrival I don't have a creditcard and I don't trust online payments. Quote Link to comment Share on other sites More sharing options...
Strungup Posted April 8, 2007 Report Share Posted April 8, 2007 I have a european model which comes with a RM-MC38EL. I wan't to buy a 35elk/40elk but when I google for it I'll only get all those crappy ebay things, also I want to pay when on arrival I don't have a creditcard and I don't trust online payments.Me Either. The 40elk will give you the Japanese , I dont know about the other , sorry Quote Link to comment Share on other sites More sharing options...
Sparda Posted April 10, 2007 Report Share Posted April 10, 2007 A lot of MDCF members have bought 35ELKs from eBay and they all worked. Perhaps get a friend with a credit card? Quote Link to comment Share on other sites More sharing options...
Traksiris Posted April 11, 2007 Author Report Share Posted April 11, 2007 Today I've ordered the 40ELK direct from sony... it cost a chunk of my left arm O_O Quote Link to comment Share on other sites More sharing options...
Strungup Posted April 11, 2007 Report Share Posted April 11, 2007 Today I've ordered the 40ELK direct from sony... it cost a chunk of my left arm O_OWhat only the ARM???????? No Left nut , or firstborn ???? Damn they lied to me. Quote Link to comment Share on other sites More sharing options...
Traksiris Posted April 13, 2007 Author Report Share Posted April 13, 2007 I got my 40elk today, somehow still abit dissapointed cus there is no korean Quote Link to comment Share on other sites More sharing options...
Strungup Posted April 13, 2007 Report Share Posted April 13, 2007 (edited) I got my 40elk today, somehow still abit dissapointed cus there is no koreanThat would be in the region settings of the MD unit not the remote. So dont be dissappointed by the remote. none of them will give you Korean characters if the MD unit itself does'nt have that ability. Edited April 13, 2007 by Guitarfxr Quote Link to comment Share on other sites More sharing options...
Traksiris Posted April 15, 2007 Author Report Share Posted April 15, 2007 That would be in the region settings of the MD unit not the remote. So dont be dissappointed by the remote. none of them will give you Korean characters if the MD unit itself does'nt have that ability.Region settings? how do I change that? I have a euro version, I unlocked the volume limit doesn't that change the region settings?Also I just noticed that I cannot see Japanese also Quote Link to comment Share on other sites More sharing options...
Richard Posted April 16, 2007 Report Share Posted April 16, 2007 Region settings? how do I change that? I have a euro version, I unlocked the volume limit doesn't that change the region settings?Also I just noticed that I cannot see Japanese alsoTraksiris you should not have to change the region settings of the unit. Please note I have given further details on getting Japanese on the RM-MC40ELK in the reply to the PM you sent me earlier. Also note that the RM-MC40ELK will not display Korean characters (only Japanese / some Chinese), the only remote that can do this is the RM-MC55ELK. Quote Link to comment Share on other sites More sharing options...
Strungup Posted April 16, 2007 Report Share Posted April 16, 2007 Traksiris you should not have to change the region settings of the unit. Please note I have given further details on getting Japanese on the RM-MC40ELK in the reply to the PM you sent me earlier. Also note that the RM-MC40ELK will not display Korean characters (only Japanese / some Chinese), the only remote that can do this is the RM-MC55ELK.Thx Rich , your the tech guy , I am the sound guy. Quote Link to comment Share on other sites More sharing options...
Traksiris Posted April 16, 2007 Author Report Share Posted April 16, 2007 Thx Rich , your the tech guy , I am the sound guy.Thank you all I got japanese titles on my remote now I wished that I hadn't bought the 40elk after discovering the 55elk... but then again the 55elk might not be aviable hereI F***ing paid €116,00 for 40elk and the HiMD was €349,- my head phones were almost €200,- Quote Link to comment Share on other sites More sharing options...
Strungup Posted April 16, 2007 Report Share Posted April 16, 2007 Thank you all I got japanese titles on my remote now I wished that I hadn't bought the 40elk after discovering the 55elk... but then again the 55elk might not be aviable hereI F***ing paid €116,00 for 40elk and the HiMD was €349,- my head phones were almost €200,- The 40 is far more functional than the 55 though . The rc level controls , the scrolling , everything about the 40 is better than the 55The 55 is designed for CD players not the MD , it will function with the MD but the 40 is Designed for that.http://forums.minidisc.org/index.php?s=&am...ost&p=83686Dont feel bad about the 40 , that would be uneeded buyers remorse Quote Link to comment Share on other sites More sharing options...
