Silly35 Posted July 13, 2007 Report Share Posted July 13, 2007 I'm searching for a charging cradle for my new MZ-DH10P i've bought on ebay. It comes without it and i cannot charge it or download music.Please help me !Other solution : if someone has an idea to transform a charging cradle for MZ-NH900 to be compatible with a MZ-DH10P ? Quote Link to comment Share on other sites More sharing options...
Stuge Posted July 13, 2007 Report Share Posted July 13, 2007 You got a new DH10P without a cradle ?? Quote Link to comment Share on other sites More sharing options...
bobt Posted July 14, 2007 Report Share Posted July 14, 2007 Will it charge off the USB cable, or will a USB charger work( like blackberry charger etc??Good luck finding something,Bob Quote Link to comment Share on other sites More sharing options...
Strungup Posted July 14, 2007 Report Share Posted July 14, 2007 You got a new DH10P without a cradle ??Dude , he said he bought it on EBAY Quote Link to comment Share on other sites More sharing options...
Silly35 Posted July 14, 2007 Author Report Share Posted July 14, 2007 (edited) Will it charge off the USB cable, or will a USB charger work( like blackberry charger etc??Good luck finding something,BobThe DH10P seems have a proprietary connection. I have never seen this type of connection on other USB devices. Edited July 14, 2007 by Silly35 Quote Link to comment Share on other sites More sharing options...
Strungup Posted July 14, 2007 Report Share Posted July 14, 2007 Here is what the cable looks like,The connector looks an awful lot like a CDMI cell phone connector Quote Link to comment Share on other sites More sharing options...
Richard Posted July 14, 2007 Report Share Posted July 14, 2007 Here is what the cable looks like,The connector looks an awful lot like a CDMI cell phone connectorIt's the same cable as the NH1 / NH3D / N10, but unfortunately can't be used to charge the unit so you will have to look for a separate cradle or order one from Sony Services. The part no for re-ordering (for the cradle) is A-1108-517-A. The model is DH10P charging cradle BCA-MZDH10P.If you are also missing the cable the best bet is to pick one of those up from ebay.* Moved to Hi-MD section Quote Link to comment Share on other sites More sharing options...
Silly35 Posted July 14, 2007 Author Report Share Posted July 14, 2007 It's the same cable as the NH1 / NH3D / N10, but unfortunately can't be used to charge the unit so you will have to look for a separate cradle or order one from Sony Services. The part no for re-ordering (for the cradle) is A-1108-517-A. The model is DH10P charging cradle BCA-MZDH10P.If you are also missing the cable the best bet is to pick one of those up from ebay.* Moved to Hi-MD sectionThanks a lot Richyhu ! I've found a sony store on the web (http://servicesales.sel.sony.com/web/productSearch.do?searchOperation=modelSearch&searchText=MZDH10P) who sell the cradle and the cable but the prices are amazing ! ( ~103$ for the the cradle and ~40$ for the cable!) At this price I prefer to buy a new one!I will purchase on ebay... Quote Link to comment Share on other sites More sharing options...
Silly35 Posted July 14, 2007 Author Report Share Posted July 14, 2007 I've found a USB cable on EBAY ! (http://cgi.ebay.fr/ws/eBayISAPI.dll?ViewIt...p;rd=1&rd=1)But I've a little last question : Richyhu, are you sure I can't charge batterie without the cradle/charging stand?If I can't which charger can I buy to do it? and where?Thanks for all your replies and long live the MDCF! Quote Link to comment Share on other sites More sharing options...
Richard Posted July 14, 2007 Report Share Posted July 14, 2007 I've found a USB cable on EBAY ! (http://cgi.ebay.fr/ws/eBayISAPI.dll?ViewIt...p;rd=1&rd=1)But I've a little last question : Richyhu, are you sure I can't charge batterie without the cradle/charging stand?If I can't which charger can I buy to do it? and where?Thanks for all your replies and long live the MDCF!I'm pretty sure - I have a DH10P myself. The USB cable powers the unit when it is connected to the PC (stops it from consuming battery), but it doesn't "actively" charge the battery so you will need the cradle I'm afraid. (Unless you have another MD unit that takes LIP-4WM batteries for which you also have the charger). Quote Link to comment Share on other sites More sharing options...
