sony MD-unit on usb?
superted
Hey people!
I have this old sony NETMD device floating around.
It was an expansionbay for VAIO laptops, but I was wondering if it is possible to get it on USB somehow.
Now it's just sitting around in the JUNKBOX, and I want to give it a function.
NETMD is for audio as far as I can recall....am I right about that?
Do you have the model number of it at all?
It should just work with a standard Mini-USB cable, that's what I've been using my MZ-710 and NH700 with! You'd need to download SonicStage though, just google 'SonicStage download' and it should be one of the top links :)
uhm that would be a problem.
It's an internal thing for a laptop with some special connector.
It's the PCGA-MDN1.
So soldering is required....
But I just can't find any info on it.
Product Features and Technical Details
Product Features
Product Description: Sony PCGA MDN1 - MiniDisc recorder
Product Type: MiniDisc recorder
Dimensions (WxDxH): 10.6 cm x 14.1 cm x 2.1 cm
MD System: MiniDisc recorder - slot-load
Technical Details
Main Specifications
Extended Specifications
General
Depth: 14.1 cm
Height: 2.1 cm
Width: 10.6 cm
MD System
Features: MDLP, Net MD compatibility
Media Load Type: Slot-load
It is for a Sony Viao Laptop .
Edited by Guitarfxr
