gbrunsdon Posted April 30, 2008 Report Share Posted April 30, 2008 well its a great very small unit but the battery life isnt all that great! So wondered - are there alternative better batteries to buy to replace the LIP-4WM?And does anyone know if you can get an external charger to use with this size of battery - as this would be very helpful at work/advice would be much appreciated...Gary Quote Link to comment Share on other sites More sharing options...
THIS SUCKS Posted April 30, 2008 Report Share Posted April 30, 2008 i have heard of people using usb battery boxes for power and charging. Quote Link to comment Share on other sites More sharing options...
an0nym0usmuse Posted May 1, 2008 Report Share Posted May 1, 2008 gbrunsdon said: well its a great very small unit but the battery life isnt all that great! So wondered - are there alternative better batteries to buy to replace the LIP-4WM?You're right about the battery life... fairly good, but not great.I'm thinking of getting the APC UPB10 Mobile Power Pack... it's an external lithium polymer battery that provides a charge via USB. I think it would work with the RH1. It's got excellent reviews on Amazon.com, and it's at a good price. Quote Link to comment Share on other sites More sharing options...
baturjan Posted May 1, 2008 Report Share Posted May 1, 2008 I recently bought the JboxMini from Macally. I looked at the APC UPB10, but the JboxMini had a smaller form factor. It's smaller than my M200. I bought it to record a week long conference. http://www.macally.com/en/Product/ArticleS...sp?ArticleID=33 Quote Link to comment Share on other sites More sharing options...
Strungup Posted May 1, 2008 Report Share Posted May 1, 2008 Sanyo Eneloop , has a new 2 AA USB pack that will work as well , I was looking at it 30 minutes ago , and it states that it will power the PSP , so it will also Power the RH1 using a standard USB cable , Quote Link to comment Share on other sites More sharing options...
bobzilli Posted May 1, 2008 Report Share Posted May 1, 2008 Now thats great news, I need to check that one out as my battery life is crap as well Quote Link to comment Share on other sites More sharing options...
gbrunsdon Posted May 2, 2008 Author Report Share Posted May 2, 2008 some really helpful advice team - thanks very much - garyguitarfxr - can you post a link to the item your'e talking about please - thanks - gary Quote Link to comment Share on other sites More sharing options...
Strungup Posted May 2, 2008 Report Share Posted May 2, 2008 gbrunsdon said: some really helpful advice team - thanks very much - garyguitarfxr - can you post a link to the item your'e talking about please - thanks - garyI will have to go back to the store and get the model number , soon as I have it I will send a link . It was pretty cool looking to , I have several Batt packs , with USB for my RH1 the two faves are my Filco 4.4 amp lithium ( Talk about Recording time ,, jeesh ) and another has 4 aa's and USB out I have a Targus USB pack 4 AAA's with a built in light , that I would be willing to part with , AAA 's are getting harder to find here in Japan at convenience stores .This Targus pack will also use AND CHARGE 4 rechargeable AAA batts , Quote Link to comment Share on other sites More sharing options...
Strungup Posted May 3, 2008 Report Share Posted May 3, 2008 Depends on the weather , been raining and cloudy too much to show it off , but when it is sunny outside it is on my Backpack , People are lookin !!!! "sugoi eco na hito da ne" !!! Quote Link to comment Share on other sites More sharing options...
