Radio FM remotes
sfbp
I have had very mixed results with remotes that have a tuner on them. Apparently the functionality is all to do with the resistance presented to the recorder, quite apart from whether the socket fits :scratchhead:
The fault I have observed on at least two of them is the radio function is either very slow or inoperable. In the latter case, it seems to mess up everything for a while (eg the jog lever functions on the remote). Unplugging from the portable seems the only way to cure this.
I have to recommend this auction - good price, fast delivery, and seems to work perfectly in all the units I tried. He has multiple items for sale. I have no connection with this vendor whatsoever.
It's an RM-MC37LT suitable, as the title says for N510/NF610 and N710/NF810 (I am not exactly sure if the 510 and 710 actually accept the special radio plug). But it also works in the NH700 HiMD, my workhorse portable, and presumably the NHF800 which is supposedly the same as the NH700 except for the radio remote. Supposedly one should get a RM-MC39LT specially built for the HiMD (I believe it has a HiMD indicator in the display, big deal!), but these seem to have full functionality.
I did fix all the NH700's to believe (service mode) that they were NHF800's but I think they still work ok with the remotes without doing that. Maybe someone knows if changing the firmware is a necessary prerequisite to using these tuners properly in the NH700. If so, the possibility exists that my problems (before) arose from the time before I changed the NVRam settings in the unit. IE that I shot myself in the foot (by using the tuner without making the model number change). :angry:
  • 3 weeks later...
