how to allow access to md
j-dawg48
just purchased a net md walkman mz-ne 410 last week, downloaded soft ware , up loaded music in to sonic stage , but could not transfer music to md , because screen showed " error with red X the media device is write protected..... so i called sony support and was told of web site where i could correct problem....... the current site showed ... " error the media device is write protect ............ solution ......... this error will ouccur if the media has been set to pervent it from being overwritten. this is called protect mode. to eliminate the error message, either replace protected media with an unprotected media or move the tab on the existing media to allow it to be accessed, data on that media may be overwritten......... i take it sony is saying to move the tab on the on the bottom left corner of the disc ????? which i did do with no results ......... any ideas out there in mini disc land , this is drivin me nuts !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! need some help bbbbbaaaaaddddd !!!!!!!!!! thanks
How many discs do you have? I would be trying another disc if you have one.
If you don't have another disc, make sure when you move the tab that the little whole near it is being covered up. This pushes a switch on the inside of the player and allows you over write information. If the hole remains open, put a piece of tape over it to cover it.
The player itself could also be damaged, or the disc is faulty. I'm not 100% sure, but the disc could also be protected by another player.
Edited by brian10161
