moving HDD - what options do I have ?
ming
G'day
I have about 70 GB of OMA files downloaded from my Hi-LP with copy protection removed.
It has been in a directory within h:\
I now will do away with the h:\ and everything will move to e:\
What options do I have to make sure SonicStage still keeps tabs on my files? Is there some text file I can do a global change? Do I use SonicStage to move files from H:\ to E:\ so it knows about the move?
Also can I replace SonicStage with MediaMonkey if I have ATRACplus stuff on my HDD? Sorry if my questions are rather noddy in nature ... I have a pile of stuff in ATRAC* and a pile of stuff in iTunes. Similar story with my digital images. Different cameras have different software to download and manage. So I am all confused and disorganised.
Thanks for any pointers. Ming
PS I just saw http://forums.sonyinsider.com/index.php?showtopic=23685 - will have to re-read it
Man --- that's serious amounts of music (especially if it is all Hi-LP!!!!!!!!)
Better idea.... Get a copy of junction.exe available from Sysinternals (taken over by microsoft but the domain still pointed there last time I looked).
Create a junction thusly:
c>\junction e:\sound h:\sound
NO, that's wrong....backwards
What you need is to mount a virtual drive (Mount point) in E:\whatever that is known as H:
I think it can be done, I just have to remember how...
(later)
1. Create a new folder called "Sound" on e:
2. Copy all your files there from h:
3. Unmount h: (physically disconnect it or use Disk Management to do so)
4. Share e:\sound to whoever you want (the wizard gives "full" to administrators r/o to rest, that should be good enough) as \\mypc\sound (where "mypc" is the name of your pc)
5. Map "Network drive" H: to \\mypc\sound and make the mapping permanent (reconnect at logon).
Presto you now have a "fake" H drive, and SoS will work perfectly.
The other technique works if you started on e: and want to "expand" to h:
Stephen
PS my NH600 is holding up beautifully, assuming you are the same Ming
