hmunster1234 Posted December 8, 2010 Report Share Posted December 8, 2010 Real Player used to support Sony MD but I don't find that it works any more. Anyone know of other software to transfer my songs onto a MZ-S1 besides Sonic Stage or Net MD? Or a way to get Real Player to transfer the songs? Quote Link to comment Share on other sites More sharing options...
THIS SUCKS Posted December 8, 2010 Report Share Posted December 8, 2010 Real Player used to support Sony MD but I don't find that it works any more. Anyone know of other software to transfer my songs onto a MZ-S1 besides Sonic Stage or Net MD? Or a way to get Real Player to transfer the songs? sonic stage is good now just download the most recent one and use that. Quote Link to comment Share on other sites More sharing options...
sfbp Posted December 8, 2010 Report Share Posted December 8, 2010 Real Player never had download support (at least any version I have seen). To do so requires secret keys and protocol from Sony. Quote Link to comment Share on other sites More sharing options...
hmunster1234 Posted December 8, 2010 Author Report Share Posted December 8, 2010 Well half of the songs I try to load onto sonic stage won't work because there protected. What's a way around this. Quote Link to comment Share on other sites More sharing options...
sfbp Posted December 8, 2010 Report Share Posted December 8, 2010 Get the originals and start again. If you don't have the CD's, you are mostly out of luck. Quote Link to comment Share on other sites More sharing options...
hmunster1234 Posted December 9, 2010 Author Report Share Posted December 9, 2010 I'm out of luck, what are you a Sony loyalist? I'm sure I can get around it. Quote Link to comment Share on other sites More sharing options...
StevenQBosell Posted December 9, 2010 Report Share Posted December 9, 2010 I'm out of luck, what are you a Sony loyalist? I'm sure I can get around it. No, you're pretty much SOL. It's 2010, there's a million ways to acquire music nowadays, it's not that serious. Unless you plan on real time transferring it back to the computer, you're going to have to acquire the tracks again. Note - I do remember back in the day being able to use Realplayer to transfer files to a NetMD device, but you still had to have Sonicstage installed on the system. from: http://www.techsupportforum.com/hardware-support/driver-support/33070-mz-n707-type-r-net-md-driver.html I wouldn't recommend using the Jukebox though, it's very slow and temperamental. RealPlayer has a Sony NetMD plugin that is much quicker and more reliable for transferring files to the minidisc (Open RealPlayer, go to Tools > Add Device, select Sony from the Browse menu, select Sony NetMD) Note: the RealPlayer plugin needs all the Sony software installed before it will work properly, even if you choose not to use SonicStage/OpenMG. But again, anyway you look at it, the only way to transfer the files is to do real time, via PC, stand alone audio CD recorder, Sony PCM-M10, Sony ICD-SX750, etc. Quote Link to comment Share on other sites More sharing options...
sfbp Posted December 9, 2010 Report Share Posted December 9, 2010 I'm out of luck, what are you a Sony loyalist? I'm sure I can get around it. I wish you every good fortune in your determined quest. Quote Link to comment Share on other sites More sharing options...
THIS SUCKS Posted December 10, 2010 Report Share Posted December 10, 2010 i remember using real player too. it was a long time ago. Quote Link to comment Share on other sites More sharing options...
hmunster1234 Posted December 10, 2010 Author Report Share Posted December 10, 2010 I tried JSymphonic but not luck with that either. Quote Link to comment Share on other sites More sharing options...
paperclip Posted December 13, 2010 Report Share Posted December 13, 2010 Or you could just flag the TOC on the disc as analog... Quote Link to comment Share on other sites More sharing options...
