How do I record in ATRAC SP on RH10?
Sony_Fan
In the word "just" (as always IMHO) lies a whole world of experience. If you are ready to enter it, be prepared for many days of frustration and annoyance, and quite possibly losing your RH10 forever.
If I were you I would buy a (cheap) unit for recording SP and then play back on the RH10. Every *other* model will do SP recording.
I've seen enough trouble with the second gen machines (actually the RH910 but they should be and probably are, the same) that I wouldn't tinker with it.
But if you read that very long thread (with the help of the service manual) you should be able to do what you want. Don't expect sympathy if you brick your RH10, though.
