Sony_Fan Posted April 30, 2013 Report Share Posted April 30, 2013 http://www.extremetech.com/computing/126195-sonys-optical-disc-archive-30-blu-ray-discs-in-a-1-5tb-minidisc-like-cassette Thought this was interesting. Quote Link to comment Share on other sites More sharing options...
sfbp Posted April 30, 2013 Report Share Posted April 30, 2013 I want one! I have been considering how to back up large quantities of data for a while. This fills a significant hole. Bluray is available but too small in capacity. Bravo Sony Quote Link to comment Share on other sites More sharing options...
cwall1108 Posted April 30, 2013 Report Share Posted April 30, 2013 Yours for a mere $7k: http://pro.sony.com/bbsc/ssr/product-ODSD55U/ That's exceedingly steep for my needs. Quote Link to comment Share on other sites More sharing options...
sfbp Posted April 30, 2013 Report Share Posted April 30, 2013 Yours for a mere $7k: http://pro.sony.com/bbsc/ssr/product-ODSD55U/ That's exceedingly steep for my needs. Agreed. But something less costly and better supported will come in due course, methinks. What I am not clear is whether this thing holds 12 x 1.5TB or whether 1.5TB is made up of 12 120GB blurays. Quote Link to comment Share on other sites More sharing options...
Sony_Fan Posted April 30, 2013 Author Report Share Posted April 30, 2013 If Sony can reduce this to the size of a standard MiniDisc, imagine the amount of music it can hold. This new type of MiniDisc could be used a new "B-MD" recorder/player. Quote Link to comment Share on other sites More sharing options...
cwall1108 Posted May 1, 2013 Report Share Posted May 1, 2013 Agreed. But something less costly and better supported will come in due course, methinks. What I am not clear is whether this thing holds 12 x 1.5TB or whether 1.5TB is made up of 12 120GB blurays. It appears to be a single cartridge with the 1.5tb capacity. Sadly that capacity is also limited to 1.5tb WORM (Write once, read many). 1.2tb with read/write is due September 2013. Quote Link to comment Share on other sites More sharing options...
Sony_Fan Posted May 1, 2013 Author Report Share Posted May 1, 2013 It appears to be a single cartridge with the 1.5tb capacity. Sadly that capacity is also limited to 1.5tb WORM (Write once, read many). 1.2tb with read/write is due September 2013. Even at 1/5 the size, it would be a 240GB Minidisc, Sony can still revive this format with this type of read/write storage. Quote Link to comment Share on other sites More sharing options...
mdsince93' Posted May 2, 2013 Report Share Posted May 2, 2013 This is 100% professional application storage solution.You would have to wait a few years for the price to drop ! Quote Link to comment Share on other sites More sharing options...
sfbp Posted May 2, 2013 Report Share Posted May 2, 2013 It appears to be a single cartridge with the 1.5tb capacity. Sadly that capacity is also limited to 1.5tb WORM (Write once, read many). 1.2tb with read/write is due September 2013. If you re-read (I just did) the specs, it says that each cartridge holds 12 optical disks. I think that means the 1.5TB happens to contain 12 Blu-ray disks. Quote Link to comment Share on other sites More sharing options...
cwall1108 Posted May 2, 2013 Report Share Posted May 2, 2013 If you re-read (I just did) the specs, it says that each cartridge holds 12 optical disks. I think that means the 1.5TB happens to contain 12 Blu-ray disks. Yes. We can both be right, yes? Single cartridge - multiple discs. Toe-may-toh, toe-mah-toh. Also found what looks to be an early release regarding this format with the cartridge opened. http://www.hughsnews.ca/sony-unveils-disc-archive-storage-system-0026613 Quote Link to comment Share on other sites More sharing options...
