punkrockaddict Posted October 26, 2013 Report Share Posted October 26, 2013 heya folks what´s your most often used device when used outdoors ? I used to take my N10 but its battery kinda sucks now. I like the DH10p ( carefully packed ) in my bag now as its sound is superb. Second one i use is the DR580.. as a backup device When change discs in the tube for example ppl use to stare at the discs again(specially those with design like the Bit Club ).I remember this happening in the mid 90´s and it seems to repeat now. Quote Link to comment Share on other sites More sharing options...
PhilippeC Posted October 26, 2013 Report Share Posted October 26, 2013 Quote Link to comment Share on other sites More sharing options...
netmduser Posted October 26, 2013 Report Share Posted October 26, 2013 wow camouflouge? Quote Link to comment Share on other sites More sharing options...
oroville Posted October 26, 2013 Report Share Posted October 26, 2013 what did you do to that MZ-RH1???? Quote Link to comment Share on other sites More sharing options...
PhilippeC Posted October 27, 2013 Report Share Posted October 27, 2013 When I bought it, the RH1 looked like this : The binder was there because of false contacts. Then I put on it a sticky fur (removed last year with the help of some Zippo fluid), it was called "Marsupilami". Jim Hoggarth repaired it already completely. Quote Link to comment Share on other sites More sharing options...
SonicFields Posted November 5, 2013 Report Share Posted November 5, 2013 On 10/27/2013 at 9:56 AM, PhilippeC said: When I bought it, the RH1 looked like this : The binder was there because of false contacts. Then I put on it a sticky fur (removed last year with the help of some Zippo fluid), it was called "Marsupilami". Jim Hoggarth repaired it already completely. That's what you call 'well used' ............take a look at some md recorders shown in the various posts at http://theretrorecordist.wordpress.com/ Quote Link to comment Share on other sites More sharing options...
PhilippeC Posted November 5, 2013 Report Share Posted November 5, 2013 Please be more specific Sonicfields, give us direct links Quote Link to comment Share on other sites More sharing options...
