brook392 Posted January 15, 2015 Report Share Posted January 15, 2015 Hello there Everyone, I have a problem with loading and ejecting discs on MDS-JE510,when I was trying to insert disc,deck pulled the disc and started makes lound mechanical noise, I tried to eject it but every time player makes the same noise and the disc is stucked in player. I think it's a problem with loading part, anyone knows how to fix that?.the player reads disc and shows all tracks, it even "plays" disc with no sound though. Thnx for any help Quote Link to comment Share on other sites More sharing options...
PhilippeC Posted January 16, 2015 Report Share Posted January 16, 2015 Ask help to jonathanpotato, he is a geat MD deck specialist http://jonathan.dupre.free.fr/ 1 Quote Link to comment Share on other sites More sharing options...
sfbp Posted January 17, 2015 Report Share Posted January 17, 2015 The JE510 is, IMHO, the one and only deck not worth fixing. There are lots available. JE520 for starters. Also decks with MDLP such as JE640, JB940, and some with Type-S processing (you may not care if you only need SP recordings since the improvements are for MDLP). Give up, use for parts. Quote Link to comment Share on other sites More sharing options...
PhilippeC Posted January 17, 2015 Report Share Posted January 17, 2015 In fact Stephen is right, if any shipping costs both ways to somebody who can help you are expensive, there is no need to repair this unit. At least, try yourself to open the deck and see if it could be a lack of some teeths on a wheel, a need of grease somewhere, a distended belt or anything that could disturb the loading of the disc. Quote Link to comment Share on other sites More sharing options...
brook392 Posted January 17, 2015 Author Report Share Posted January 17, 2015 thnx, I'll try to opened and check what makes that noise Quote Link to comment Share on other sites More sharing options...
