Options for titling SP disks?
fyrebug
Hi everyone, so I'm a full fledged N00b.
I'm sure some ways are easier, harder, cheaper, expensive. Just wondering what my options are.
I prefer recording SP disks via optical out, and I'm not interested in netMD compression.
I've seen ir remotes with keyboards on them and I've seen hacks for the remote that allow old dos machines to program the disk titles via serial or printer port.
Is there a way to perhaps edit the titles of the disk that have already been recorded inside a netMD? Would sonicStage allow me to do this? I've seen there are some install issues so I wanted to ask first before installing it.
This is the list of devices I have if it helps
MZ-e10
MZ-R55
MZ-R90
MetMD MZ-N707
bookshelf CMT-M333NT (netmd with optical and usb)
MDS-JE510
thanks.
Just record first (if you use your computer with a good DAC inside or outside - to record Flac flies - you can use foobar2000 withe the Posttracksilen DSP to create gaps). Then put the MD inside your Net-MD unit and connect it to your Pc. Open "Sonic Stage CP" (last version, see download section, you can even install well for any unit on Windows 8.1 64bit). You will get all your tracks, you just need to edit each track (copy-paste track names one by one from foobar2000 if you have used it). If you have errors, record again or split / cut tracks with your portable / deck unit.
Ok! this is great, thanks everyone for your replies!
I'm on windows 7 64bit, so I'll go through the hassle of installing sonic stage but it'll be worth it.
right now I record with winamp and have a plug-in that adds 3 second delays between tracks, but if foobar2000 is better I'll use that.
I was really worried it was going to be more difficult so this is really good news.
Winamp is Ok, I used it before foobar2000. I knew Wincue plugin also (I used 2 seconds gap). What is important is to use a good output, preferably digital foobar2000 / Winamp : DS, KS, Asio (with exclusive application use of the audio output). You have good external DAC for less than 100$ (Creative HD USB).
Ultimately all audio signals start out as analogue.Staying with digital is usually good, except that compression and conversion artifacts (yes, even "uncompressed, lossless" PCM is in some sense compressed, so please nobody any of that hogwash about perfection through not using compression) can tend to build up depending on what you do to it. Sony is very careful with their digital signals - other mfrs may be less so.
Sometimes it's simpler to do a good conversion back to analogue and then record that digitally, especially if the conversion is doing a bad job, Follow what sounds good (assuming your ear can tell!) and always use the same steps whenever you can.
There are no simple answers to your question. One unfortunate thing about the means you describe are that the old ATRAC compression (before ATRAC3 and ATRAC3+) although sounding good, is not actually a very accurate codec. Nice yes, warm yes, but accurate maybe not. The strength lies in all the OTHER stuff Sony does to clean up the signal on their amazing MD decks, such that the result can sound better than the original. The other problem is that ATRAC itself is sort of on an island, and to get off the island you have to:
a. buy an MZ-RH1/MZ-M200 (same thing)
b. convert the compression to something which can be stored on disk.
It doesn't matter what the reasons are - but it's unlikely that storing the actual MD data from your SP disks will be possible or useful.
With ATRAC3+ on the other hand (assuming you don't want to spend 5x the real estate on PCM) you can get really very good recordings (of someone else's digital signal) and transfers. The japanese version of the flash walkmen actually allows you ATRAC recording, I just haven't tried it yet.
In the post-MD world PCM recordings are very nice, however most people end up converting them to "lossless" like FLAC (and others), to save space.
Yes, as said before, follow what sounds good. I have some kit that without doubt gives a more accurate sound (semi-pro gear) but it certainly doesn't sound as "nice" as my minidiscs. Never mind about specs, facts, figures and what other people might say - trust your ears. After all you're the one listening to it.
By the way, although you can't edit NetMD tracks on an MD deck you can alter titles. I noticed a couple of spelling mistakes on one of my NetMD discs and it was no problem to correct them on my JE480.
And I'm curious, a Flash Walkman that allows ATRAC recording? Which model is that?
