Panasonic SJ-MJ88 - AA Battery Case
Hello
I was wondering if someone knew what is the specific type of AA-Battery case Panasonic SJ-MJ88 uses. In the User Manual it shows that there is a possibility to use one, but it is in japanese so I have no idea does it say what kind to use. If anyone could tell me what kind to use it would be really helpfull.
Thanks in advance.
-Tuukka Hokkanen
I am guessing that it may only ever have been an included accessory with those Panasonic MD portables that it worked with? Not sure how easy it will be to locate one on its own but you might be able to find one included with a player on eBay etc, although this might obviously cost a fair bit...
Good luck anyway!
  • Richard changed the title to Panasonic SJ-MJ88 - AA Battery Case
