JulianPH Posted May 3, 2020 Report Share Posted May 3, 2020 Are there any deck models that have a MD player and CD burner? Quote Link to comment Share on other sites More sharing options...
bluecrab Posted May 4, 2020 Report Share Posted May 4, 2020 5 hours ago, JulianPH said: Are there any deck models that have a MD player and CD burner? None that I know of...plenty of CD/MD, but not the other way. I use separate standalones for that...Sony MDS-E10 & HHB BurnIT. Quote Link to comment Share on other sites More sharing options...
JulianPH Posted May 4, 2020 Author Report Share Posted May 4, 2020 Thanks for your reply. I ma just convened that one day Sonic will stop working on my old laptop and then my files will be lost. If I connect my MD to a CD burner then the quality will be lost bec it is not digital. so, I am trying to find a way to continue putting tracks into my live concert MD recordings and those tracks transfer to a CD that I burn. It works beautifully with Sonic but once that’s gone! Best wishes Julian Quote Link to comment Share on other sites More sharing options...
freddyjollo Posted May 4, 2020 Report Share Posted May 4, 2020 why will they be lost? you can remove the encryption so they can be transfered to another pc or even convert them to mp3 - Sony included such a means didnt they? Quote Link to comment Share on other sites More sharing options...
JulianPH Posted May 4, 2020 Author Report Share Posted May 4, 2020 I tried to used the software CD to load the programme onto my new laptop but it would not work. I suspect the programme is too old for the operating system. So that's what I mean by 'lost'. Once my old laptop dies I won't be able to download my MD sound files to Sonic Stage or edit them. Quote Link to comment Share on other sites More sharing options...
sfbp Posted May 4, 2020 Report Share Posted May 4, 2020 Nah, you should be able to run SS for the foreseeable future, provided your RH1 has the 64-bit driver. It's fine on W10 despite Microsoft's best efforts...... Quote Link to comment Share on other sites More sharing options...
JulianPH Posted May 5, 2020 Author Report Share Posted May 5, 2020 Hello. Managed to get the SS onto Windows 10 Pc now but when open it keeps crashing and says I have to register. Registration site is not active. Photos-getting these error messages. Can’t work out which driver I need if any thanks so much for your help! Quote Link to comment Share on other sites More sharing options...
sfbp Posted May 5, 2020 Report Share Posted May 5, 2020 I'm assuming you have 64-bit Windows 10. If not (ie 32-bit Windows), these instructions are different. 1. You must always run Sonic Stage as an administrator. This is a matter of changing your account type so you are always logging on as one. 2. You need to install the NetMD driver from here. You need to disable mandatory driver signing for one boot cycle in order to get the (unsigned) driver installed. Instructions are everywhere (all over this forum), but the most important thing is you have to follow the steps in the first post (it may not matter, but you do have an RH1) of the following thread: Quote Link to comment Share on other sites More sharing options...
