kris01 Posted July 17, 2020 Report Share Posted July 17, 2020 I wonder how to take advantage of the fact that the MD has a dynamic range of 105 and the CD has 96. Quote Link to comment Share on other sites More sharing options...
NGY Posted July 17, 2020 Report Share Posted July 17, 2020 On 7/17/2020 at 4:53 PM, kris01 said: I wonder how to take advantage of the fact that the MD has a dynamic range of 105 and the CD has 96. Expand - you can take advantage of 20 or 24 bit, if you have such sources - you can do oversampling from 16 bit sources (CD for instance) - you can make recordings with higher dynamic range than of a CD (using a capable microphone, for example) To hear the difference though you would need a very good quality sound system (amplifiers and loudspeakers), as well as an acoustically proper environment (=listening room). Theoretically, human ear has a ~140 dB dynamic range, but the real perception is influenced by many factors. Quote Link to comment Share on other sites More sharing options...
kris01 Posted July 18, 2020 Author Report Share Posted July 18, 2020 So if I record music from Tidal 24 bit it should sound theoretically better than CD? Quote Link to comment Share on other sites More sharing options...
NGY Posted July 18, 2020 Report Share Posted July 18, 2020 On 7/18/2020 at 5:21 AM, kris01 said: So if I record music from Tidal 24 bit it should sound theoretically better than CD? Expand There is a few things we should distinguish here: 1./ The sound quality output from the D/A converter of an MD device vs. the sound quality of the same audio material recorded via ATRAC, on the same device ATRAC is a lossy audio format by design, and even being technically superior to other lossy formats, still there can be audible differences to the original audio, plus there is a significant "subjectiveness" factor. 2./ Tidal offers different audio quality options Only the highest one ("Master") has better than CD quality. Recording to MD from such 24 bit master files should yes, sound theoretically better than recording to MD from a CD quality source. Their second best option ("HiFi") is exactly the CD quality, and the remaining two ("High" and "Normal") are lossy, so these are probably out of question in this context. 1 Quote Link to comment Share on other sites More sharing options...
kris01 Posted July 18, 2020 Author Report Share Posted July 18, 2020 Thank you for explanation. Quote Link to comment Share on other sites More sharing options...
PhilippeC Posted July 19, 2020 Report Share Posted July 19, 2020 same same Quote Link to comment Share on other sites More sharing options...
