Mr. Milchgraf Posted August 2, 2023 Report Share Posted August 2, 2023 Hello all, a year ago I bought a MDS-JE510 at a flea market. It has the classic eject error with the microswitch as described in this video: classic eject error fix After I fixed the error, the player ran without problems. I had not used the player a little longer and it stood around unused. But since yesterday it has a weird issue. It pulls the minidisc in and then says "Welcome" and "Eject" alternately and tries to eject the disc. Unfortunately the eject does not work. So I always have to get the disc out manually. In rare cases it accepted the disc and played it without problems. I have tried with many different discs. But the problem is always the same. Here I have a few videos about the error: Player working, but behaving strange when inserting disc Strange Eject Error Has anyone had the same issue and can help me out? Quote Link to comment Share on other sites More sharing options...
BearBoy Posted August 3, 2023 Report Share Posted August 3, 2023 Hi @Mr. Milchgraf - welcome to the forum. I've got no direct experience of the MDS-JE510 (I do have the earlier MDS-JE500, which I think is very similar, but the eject mechanism has, so far, been fine). There are a couple of older threads here relating to eject issues with the 510. Not sure if any of them offer any possible things to try? Quote Link to comment Share on other sites More sharing options...
kgallen Posted August 20, 2023 Report Share Posted August 20, 2023 I just watched your videos (thanks!). I'm still tempted to think that disc detection microswitch is not happy. Did you replace the switch or "rectify" the activation pressure on the switch? I think I'd look at that switch again as otherwise your machine looks happy. (Although on first watching I thought the load was a bit sluggish but it does at least look smooth). Quote Link to comment Share on other sites More sharing options...
