Bios settings
barryjohnson
Hi. Looking for help please.
I have an older vaio laptop model number PCG91211M.
I am trying to put in a ssd drive. I don't have a docking station fir hard drives to clone the new ssd from the original drive in the laptop.
I have made a usb windows start up stick but can't seem to find how to get the boot screen up when I start windows to change the boot legacy to go from the usb and not the HD.
I've tried most of the F keys to no avail.
It doesn't boot automatically from the usb with the new HD in.
It just says no operating system found.
Any help would be brill.
1 answer to this question
You probably need to reinstall windows. Make a USB stick with the Windows 10 install image (you will find an ISO somewhere).
If you're on Windows 7 all bets are off BUT your W7 license key will serve as a W10 one.
Or find a friend with a duplicating dock. They cost less than a new copy of Windows.
