album art for NW a808 problem
wham44
Hey guys need some help... my music files used to have album art from my previous ipod.. it is viewable when i trnasferred it into sonicstage... however when i put the songs into the sony the art is nowhere to be seen on the music file even thought viewable on the alubm page... then i tried using the find cd info button.. they found another album art for me and i applied it to all the songs... however the art is still not viewable for some!! argh can anyone help?
6 answers to this question
Hi what i had to do was apply album art to all songs in the album. this option comes up if u are in the album view of sonic stage and you apply album art to an album. you must have saved the album art somewhere like my pictures then just drag it from the folder you save it in and drop it on ot the album in Sonic. it then pops up with this question do you want to apply to all osngs in album. i had to re-apply all album art for over 100 artists/albums :sad:
hope this helps!
Hey wham,
To make sure your album art works, you can either just drag and drop them from iTunes or if you are loading in a jpeg or something from elsewhere, you have to make sure that the image is resized to 600x600 pixels. It must be that size in order for the NW-A800 to display it. Hope that works.
Hey wham,
This is not really true - it helps if your JPEG is square (but doesn't matter) but there are no restrictions on size as Sonic Stage will accomodate it no problem and it will transfer fine to any unit.
Yeah, the image size doesn't matter. SonicStage and the player will adjust image for proper viewing.
Edited by Zizone
Yeah, the image size does matter. SonicStage and the player will adjust image for proper viewing.
I just meant it doesn't have to be a specific pixel size when you import album art. I helps if it is already square to avoid SS adding white borders to a rectangle.
Edited by richyhu
I was just agreeing with your previous reply.
I made a mistake. I meant "doesn't" but accidently wrote "does." Sorry.
I editted it now though.
Edited by Zizone
