beakster Posted July 23, 2007 Report Share Posted July 23, 2007 Hi,Does anyone know whether the NW808 and the BCRNWU3 cadle are compatible??sony says;Compatible with the following WALKMAN models: NW-S603, NW-S605, NW-S703F, NW-S705F, NW-S706F. but that was last updated in november 06.Cheers Quote Link to comment Share on other sites More sharing options...
0 Shinji Ikeda Posted July 23, 2007 Report Share Posted July 23, 2007 Yes the NW-A800 series is compatible with the BCR-NWU3 cradle. You should use the stand that came with the NW-A808, but you do not need it. The great thing about this stand is that you can use it to charge the NW-A800 without the use of your computer, or can charge it with your computer.I am using the stand with both the NW-S706 and NW-A808.The BCR-NWU3 supports any Network Walkman with a WM-Port. Quote Link to comment Share on other sites More sharing options...
0 beakster Posted July 23, 2007 Author Report Share Posted July 23, 2007 Yes the NW-A800 series is compatible with the BCR-NWU3 cradle. You should use the stand that came with the NW-A808, but you do not need it. The great thing about this stand is that you can use it to charge the NW-A800 without the use of your computer, or can charge it with your computer.I am using the stand with both the NW-S706 and NW-A808.The BCR-NWU3 supports any Network Walkman with a WM-Port.Thanks for your help I shall order one now. Quote Link to comment Share on other sites More sharing options...
0 beakster Posted July 23, 2007 Author Report Share Posted July 23, 2007 Yes the NW-A800 series is compatible with the BCR-NWU3 cradle. You should use the stand that came with the NW-A808, but you do not need it. The great thing about this stand is that you can use it to charge the NW-A800 without the use of your computer, or can charge it with your computer.I am using the stand with both the NW-S706 and NW-A808.The BCR-NWU3 supports any Network Walkman with a WM-Port.Is the port on the NWA1200 a WM-PORT?? Quote Link to comment Share on other sites More sharing options...
0 markey Posted July 23, 2007 Report Share Posted July 23, 2007 Is the port on the NWA1200 a WM-PORT??Unfortunately not, it has it's own proprietory connection. Quote Link to comment Share on other sites More sharing options...
0 Shinji Ikeda Posted July 23, 2007 Report Share Posted July 23, 2007 Is the port on the NWA1200 a WM-PORT??The WM-Port was introduced with the NW-S600 and NW-S700 series. As far as I know only the NW-S600, NW-S700 and NW-A800 series have the WM-PORT. Quote Link to comment Share on other sites More sharing options...
0 beakster Posted July 23, 2007 Author Report Share Posted July 23, 2007 (edited) Unfortunately not, it has it's own proprietory connection.I thouught it might have been to much to wish for. Never mind, I'll add the leads to my ever growing pile of proprietory cables. Why cant manufacturer's stick to standard usb leads A & B. I have a sony camera with a lead that looks like a wiring harness from a car!! Edited July 23, 2007 by beakster Quote Link to comment Share on other sites More sharing options...
0 Shinji Ikeda Posted July 23, 2007 Report Share Posted July 23, 2007 I thouught it might have been to much to wish for. Never mind, I'll add the leads to my ever growing pile of proprietory cables. Why cant manufacturer's stick to standard usb leads A & B. I have a sony camera with a lead that looks like a wiring harness from a car!!Yes in an ideal world that would be perfect, however the standard USB leads restrict the design of future electronic devices. I would agree with too many prosperity cables. There should be various standards for USB standards. I have one with two A and two B cables. Quote Link to comment Share on other sites More sharing options...
0 Zizone_ Posted July 24, 2007 Report Share Posted July 24, 2007 (edited) I thought Sony's decision to have BCR-NWU3 support both NW-S700/600 and NW-A800 was a pleasant surprise. I hope BCR-NWU3 will continue to be compatible with future Walkmans, since the cradle isn't really cheap. But I miss the cool light that BCR-NWU1 (I hope the name is correct, the one supported NW-A1000 series) had.Since the introduction of Ipods, Sony stopped supplying cradle with Walkman out of the box to keep the price low... sigh... sort of missing good old MD days.Oh, and what's up with not supplying Walkman trademark soft bag?!? I can't even buy one now days... only leather ones. I believe the last model to supply soft bag was NW-E400 series, which I am still using for my NW-S706F. Edited July 24, 2007 by Zizone Quote Link to comment Share on other sites More sharing options...
beakster
Hi,
sony says;
Cheers
8 answers to this question
