stargazer_tom1 Posted October 30, 2007 Report Share Posted October 30, 2007 Hi i was wondering why sony has dropped remote connectivity on their most recent DAPs? Does anyone know if any future walkmans will have the ability to connect a remote? I want to upgrade from my a1000Thanks Quote Link to comment Share on other sites More sharing options...
0 Ascariss Posted October 30, 2007 Report Share Posted October 30, 2007 don't count on it, unless the remote has bluetooth built into it. Quote Link to comment Share on other sites More sharing options...
0 LG1_ Posted October 30, 2007 Report Share Posted October 30, 2007 For once someone who think like i do!!!I solved the problem but it costs a pretty peny.Get the WLA-NWB1 and some BT Earphones that support AVRP and your problem is solved.I said it wouldnt be cheap but considering remotes retail for $100+ this solution isnt to bad at $180+I got the WLA-NWB1 and the motorola s705 and only cost $150 AUD on eBay, maybe you will be lucky too.And also it works!Pause, Play, Rewind \ Previous Track, Fast Foward\ Next TrackBut unfortunatly no shuffle or repeat off\on,Hope this helps Quote Link to comment Share on other sites More sharing options...
0 stargazer_tom1 Posted November 8, 2007 Author Report Share Posted November 8, 2007 Thanks for the info,A wireless remote sounds great!So wired remotes have been faded out then? Quote Link to comment Share on other sites More sharing options...
0 LG1_ Posted November 8, 2007 Report Share Posted November 8, 2007 Until they decide to make one, but judging on responces here i dont think there will be.Considering the only way would be through the wm-port i dont see it happening Quote Link to comment Share on other sites More sharing options...
0 aob9 Posted November 8, 2007 Report Share Posted November 8, 2007 I think they are concentrating on bluetooth now..............wireless is the way to go. Sony Ericsson has developed a watch that will integrate with your mobile phone. It's a nice touch but ludicrously expensive.Personally, I think it is a good idea, I had a remote for my HD1 but I found it very cumbersome. Quote Link to comment Share on other sites More sharing options...
0 antiipod Posted November 18, 2007 Report Share Posted November 18, 2007 Wireless is definitely a great way to enjoy your music. I have brought my walkman and bluetooth headphones from www.yesasia.com. Btw they have those so called Japan only walkmans such as NW-S71X and NW-A91X, with all those softwares and nice stock earphones. That's one way to get bluetooth stuff, walkman and other stuff if you want Quote Link to comment Share on other sites More sharing options...
stargazer_tom1
Thanks
6 answers to this question
