2many 0 Report post Posted July 18, 2019 It would be nice if the minidisc community portal had a cross reference chart of some kind for interchangeable parts. Or even a thread as a go to place for this type of thing. Or am I just missing this? I have been going round and round to find proper belts for my units. On suggestion I bought 7 belts off ebay that did not work for me. I think they were a bit too small so that when installed they put the pulley on a bind. They were listed as 17mm, but no other description is given. I found rubber bands that work, but their longevity is suspect. A data base stating which minidisc carrage is used in each unit would be of help when searching for a belt. For instance in searching ebay I found a belt for the je 440 and 480 and the only description is that it is a gesco 2.2 square belt. In searching for belts to fit a 940 I found a listing and those are gem3.5 by gesco I believe. What do those numbers refer to for the home repair guy? If I were to find some wholesale belt place how do I know what I need? I found a listing for the mds e-12 but they give no description at all. Diamentions of the belts would be a plus. These things might be worth a dollar...or pennies? But they charge like it is the last belt on earth and they are keeping it a secret. I just bought the last two designated for the mds e-12 and now the seller, (in portugal) has updated their listing to show two more are available! I would have bought three! There are 50+ belt packs you can buy, but that would be a crap shoot. And by the picture, there is nothing in there small enough. They state that the range begins at 40mm. Global electronics and web spare parts both have over 5,000 belts listed for everything from a kraco in dash cassette to a norelco shaver. They have no searchable database and use a generic picture for the belts. The listings are a jumble of all belts and model numbers in a mixed order. Very difficult to navigate and expensive. At least I have purchased from them before and got the right pack of four belts for a double cassette deck. Anyway, my post here might be of some help to others. I am no electronics repairman, but I fix things. Who can afford service when you have a hundred components? I have been on the phone, I have gone around town, repair men are retiring and the small parts shop is gone. I found one guy who gave me a couple wrong size belts. N/C (thankfully) So I have just purchased 6 jb940 belts and 2 mds e12 belts on line. I was curious, I have not had to take any minidiscs apart until recent. So I looked in some. I have an e10 but have not looked in there. (so I wonder about it) The 940 and a e12 are very similar. The same belt should work in each. A jb930 is a different animal. The load tray is gear driven! I would suspect my 920 is as well. No disc errors and c-13's are going to happen there, unless you jam it and bust a gear. Check my pictures below. The e-12 has a metal cover over the transport (for some reason). The 940's cage has a place for that cover and screw holes for it, but no cover. The 940 has two ground wires the e-12 does not have. And you will be able to pick out the 930 due to it's nice white transport tray GEARS! mds e-12 with it's metal lid mds jb940 has no lid mds jb930 a whole different transport I'll show you the pictures from the top too... Global electronics solutions has a listing which includes the jb940. A gesco 2.2 square belt Seller : amecbol Item location: Woodside, New York, United States Sony HCD-MD595 Sony HCD-VZ50MD Sony HCD-ZX50MD/MDS-JB940 GES2.2 SQUARE BELT ebay item # 123028753051 $6.95 shipping $290 Seller : web_spare_parts Item location: Europe, Portugal Sony MDS-E12, MDSE12 Belt Kit For MiniDisc (1 Belt) ebay item # 232891402025 $8.97 shipping $399 Above, I bought...we will see. Below, did not work in my e-12 Seller : cnh_03 Item location: Raithby by Spilsby, United Kingdom 17mm Rubber Drive Belt for Cassette Deck/Player, CD ROM, DVD Player etc ebay item # 192420535089 $1.23 shipping $2.42 Quote Share this post Link to post Share on other sites
sfbp 8 Report post Posted July 18, 2019 When you have eliminated...... What's the (congealed) grease situation? Something stopping motion maybe..... Quote Share this post Link to post Share on other sites
kgallen 5 Report post Posted July 18, 2019 The eBay seller I used has a pack with 17, 19, 22, 25 mm belts plus bigger https://ebay.us/d1v7nU At the moment he’s not asking for your life savings. You say the 17 is too small so is it worth getting this pack and trying the 19 or maybe the 22? But you do say the disk binds early on so I’m not sure how the 17 can be causing this! I know this is hit and miss but we don’t have a Sony spec or a pristine example to measure. I’m sceptical these high price belts are known to be the correct diameter and thickness. How do they know this? Do they actually have a spec or are they guessing by trial and error like the rest of us. If you’re sick of black belts then I like others tried those denture bands. This gave me a clue to the size but I didn’t want a rough cut piece of elastic in my machines hence hunting for some true drive belt of a usable size. Kevin Quote Share this post Link to post Share on other sites
kgallen 5 Report post Posted July 18, 2019 Also note many drives are the same mechanically. So for example 440, 480, E10 and E12 are all variants on the MDM7 drive and mechanically identical. So the same belt - the 17/1 worked for me in all these machines. But for some reason not in your E12. I don’t understand the reason. Other drives like the MDM5 in the 520 and 530 I think are all gears, no belts at all. Quote Share this post Link to post Share on other sites
kgallen 5 Report post Posted July 18, 2019 I did start a bit of a drive list on a spreadsheet - I just went around the service manuals and noted what was specified. But I haven’t done all (Sony) machines as there are many and I didn’t have the need. Also on the list I added the OP type (A/B/E). Quote Share this post Link to post Share on other sites
2many 0 Report post Posted July 18, 2019 20 hours ago, sfbp said: When you have eliminated...... What's the (congealed) grease situation? Something stopping motion maybe..... I am lost in the nature of your question. In what it is in reference to. Quote Share this post Link to post Share on other sites
2many 0 Report post Posted July 18, 2019 16 hours ago, kgallen said: The eBay seller I used has a pack with 17, 19, 22, 25 mm belts plus bigger https://ebay.us/d1v7nU At the moment he’s not asking for your life savings. You say the 17 is too small so is it worth getting this pack and trying the 19 or maybe the 22? But you do say the disk binds early on so I’m not sure how the 17 can be causing this! I know this is hit and miss but we don’t have a Sony spec or a pristine example to measure. I’m sceptical these high price belts are known to be the correct diameter and thickness. How do they know this? Do they actually have a spec or are they guessing by trial and error like the rest of us. If you’re sick of black belts then I like others tried those denture bands. This gave me a clue to the size but I didn’t want a rough cut piece of elastic in my machines hence hunting for some true drive belt of a usable size. Kevin Kevin. I agree with all you are saying. I wonder how and where belts are measured in the industry. I do not know how to call out specifics to a wholesale belt supplyer. Regarding my experiance and observation with the UK 17mm belt, my gut feeling is that an 18mm belt may do the trick. As far as mm’s and judging the ebay ad, they are referencing the geneal outside diameter. And right, in my case, with the 17mm installed, there is something going on at the very beginning of insertion and engaugement. A sony spec would be a blessing. No one has time for our little belt issue. Did they test different belts in all machines? No, impossable. In a perfect world, going to a belt supplier and rifling through and testing their various product would be nice. In the end, the reason for creating this post is to try to come up with a general consensus, clarify terminology, create cross references and clear up the darkness regarding this issue. For me and hopefuly for others. When I get these new belt shipments in hand. I will compare, test and report my findings. Quote Share this post Link to post Share on other sites
2many 0 Report post Posted July 18, 2019 16 hours ago, kgallen said: Also note many drives are the same mechanically. So for example 440, 480, E10 and E12 are all variants on the MDM7 drive and mechanically identical. So the same belt - the 17/1 worked for me in all these machines. But for some reason not in your E12. I don’t understand the reason. Other drives like the MDM5 in the 520 and 530 I think are all gears, no belts at all. It is hit and miss with any info you may garner from an ebay ad. In post #1 of this thread, web spare parts lists a model specific belt for the mds e-12. With them, no other models were mentioned. Global electronic solutions lists the belt for the jb940 and two others, but leaves off the fact that this should very well fit the e10’s and 12’s. Should fit many others too! I am new to the deck internals. Have not had troubles until now. A list of all decks using the mdm7 transport would have been of help to me as I scrolled through 5,000+ listings to try to find what they had available. So for the benefit of the md community I will post my observation and experiance. What is the name of the transport inside the jb930? What other home deck transports are there? You and me... don’t understand why the 17/1 did not work for me! For the record, I tried a number of them, in and out, along with going back to the original stretched belt and using rubber bands. This being done to two different e-12’s. With identical results. I do not think I failed to install them right... it is too easy and you can see it is in place. Result, 17mm band does not work. I will say they are visually smaller in diameter, thicker than original sony and lack the expandability of a rubber band similarly sized to the 17mm. Quote Share this post Link to post Share on other sites
2many 0 Report post Posted July 19, 2019 Op type? A/B/C... Over my head. I am new to the internals and the terminology. But I will add one other thing that would help me as I go along in md life. At one point, I decided a sony e-12 service manual would be a plus in my world. Searches came up empty. Hard to get a copy of them? Quote Share this post Link to post Share on other sites
kgallen 5 Report post Posted July 19, 2019 Most Sony MD service manuals are on manualslib, minidisc.org or elektrotanya and come up pretty readily with a google search. Here: https://elektrotanya.com/sony_mds-e12_md_recorder.pdf/download.html also note that depending what information you're after many of the service manuals are very similar in content. What varies of course is the exact drive model, optical pickup (OP), additional features (like say the RS232 on the E12 not on the E10), and the button combinations to get into service mode. OP = optical pickup - the laser and focus module. KMS260A, KMS260B and KMS260E are the usual types found in the Sony MD drives. Sometimes they are interchangeable, but often there are caveats like exactly how they are set up for e.g. Laser power. Plenty of threads on this site on this! Quote Share this post Link to post Share on other sites
2many 0 Report post Posted July 19, 2019 That is great. Thank you for steering me in that direction. Quote Share this post Link to post Share on other sites
kris01 1 Report post Posted July 20, 2019 Belt for MDS-JB980QS fits for next MDS models and not only MDS https://pl.eetgroup.com/i/422702501-Sony-Belt - Mini Disk MDS-JB940 - Mini Disk MDS-JB980 - Mini Disk MDS-JE440 - Mini Disk MDS-JE470 - Mini Disk MDS-JE480 - Mini Disk MDS-JE640 - Mini Disk MDS-JE770 - Mini Disk MDS-JE780 - Mini Disk MDS-LSA1 - Mini Disk MDS-NT1 - Mini Disk MDS-PC3 - Mini Disk MDS-S50 - Mini Disk MDS-S9 - Mini Disk MDS-SE9 - Mini Disk MXD-D4 - Mini Disk MXD-D40 - Mini Disk MXD-D5C this one fits https://pl.eetgroup.com/i/499953701-Sony-Loading-Belt , 33 mm 1,5 x 1,5 mm MDS-JA20ES MDS-JA333ES MDS-JA555ES Quote Share this post Link to post Share on other sites
sfbp 8 Report post Posted July 20, 2019 On 7/18/2019 at 4:14 PM, 2many said: I am lost in the nature of your question. In what it is in reference to. It cannot be the belts at fault. Something systemic is causing all your mechanisms to be extra sticky. Congealed grease maybe? Looks like I was wrong about belts being "it", my apologies. Quote Share this post Link to post Share on other sites
kgallen 5 Report post Posted July 20, 2019 34 minutes ago, kris01 said: Belt for MDS-JB980QS fits for next MDS models and not only MDS https://pl.eetgroup.com/i/422702501-Sony-Belt - Mini Disk MDS-JB940 - Mini Disk MDS-JB980 - Mini Disk MDS-JE440 - Mini Disk MDS-JE470 - Mini Disk MDS-JE480 - Mini Disk MDS-JE640 - Mini Disk MDS-JE770 - Mini Disk MDS-JE780 - Mini Disk MDS-LSA1 - Mini Disk MDS-NT1 - Mini Disk MDS-PC3 - Mini Disk MDS-S50 - Mini Disk MDS-S9 - Mini Disk MDS-SE9 - Mini Disk MXD-D4 - Mini Disk MXD-D40 - Mini Disk MXD-D5C Can add MDS-E10 and MDS-E12 to that list too, since they are also MDM7 variant drives. 440,640,940,S50,470,770 = MDM-7A 480,780 = MDM-7S1A E10, E12 = MDM-7SC Quote Share this post Link to post Share on other sites
2many 0 Report post Posted July 20, 2019 Thank you kgallen I like the way your cross reference chart is shaping up! I was hedging my bets as to whether the same belt for the 940 would be prooer for my e-12’s. Thus purchsed from two different suppliers. I will be curious how they match up wigh each other. sfbp, I now am convinced that I have a belt issue. And thanks for your help trouble shooting. Quote Share this post Link to post Share on other sites
2many 0 Report post Posted July 23, 2019 Global electronic solutions belt is the big one in this picture. $45 for 6 rubber bands. Now I try to get my money back. Quote Share this post Link to post Share on other sites
kgallen 5 Report post Posted July 23, 2019 Which of those belts are ‘old’ from your machines and which are new (big one is new, understood). E12 and 940 are both MDM7 variant drives so they’ll use the same belt. Can't really tell from the picture but a square section or round section belt is needed not a flat section one. Kevin Quote Share this post Link to post Share on other sites
2many 0 Report post Posted July 23, 2019 All four are old belts In the picture, the three are original e12 belts and the one is original 940 belt. And yes, all four seem to be identical belts. They are as marked on the paper. Only the big belt is a new belt. It is thicker and larger diameter and WAY too big. The big belt is one of six I purchased from global electronic solutions. It was listed as for the mds jb940. (Among other machines) Yet obviously that belt is wrong. My god how hard can this be to get a tiny little belt? Several posts back, Kris01 posted a link which I would have to translate. Below the link is 33mm x 1.5 x 1.5 is that the belt I need? Quote Share this post Link to post Share on other sites
kgallen 5 Report post Posted July 23, 2019 Maybe you could mark up your paper with any other info you can determine from the belts - "old" and "new", cross-section shape (square, round, flat), thickness if you can measure it (1mm? 1.5mm? etc) and then circumference - or diameter if you can get the belt roughly circular. Then re-take a photo. This would be a useful back-reference for old/stretched belts at least given we don't have any Sony data. Also if you have some new belts - those 17mm ones for example. Maybe they could be added to the picture and marked up accordingly (17mm new, round) as an A-B comparison? If you have some 5mm gridded paper or graph paper to lay out your whole specimen collection on that would be even better! Quote Share this post Link to post Share on other sites
2many 0 Report post Posted July 23, 2019 Afaid I am not very technically inclined regarding a micrometer. Nor do I have the tools. Yet I will give it a go right now and then post. Stand by. Quote Share this post Link to post Share on other sites
2many 0 Report post Posted July 23, 2019 That link that Kris01 posted, my computer translated the language. It is EET europarts sony loading belt product number 499953701 ean upc 5705965918319 they do not give specs. The belt is round, that’s a start. It says the price is 47.43 pln (with VAT) what is that? Quote Share this post Link to post Share on other sites
kgallen 5 Report post Posted July 23, 2019 What device is 499953701 for? It''s square section. Anyway 47.43 Polish Zloty's is about 12.50USD (July 2019). (VAT is EU sales tax, "Value Added Tax"). Kris references 422702501 for JB980 etc (which is also square-section) and that is about 13USD. But nothing more to be gleaned on the spec from this site... and I'm certainly not going to be spending that sort of silly money on a single belt! Quote Share this post Link to post Share on other sites
2many 0 Report post Posted July 23, 2019 Do any of these photos help? Quote Share this post Link to post Share on other sites
kgallen 5 Report post Posted July 23, 2019 They might if I had the vaguest of ideas of how to read an imperial micrometer and what the scale of the graduations are! Quote Share this post Link to post Share on other sites
2many 0 Report post Posted July 23, 2019 11 minutes ago, kgallen said: What device is 499953701 for? It''s square section. Anyway 47.43 Polish Zloty's is about 12.50USD (July 2019). (VAT is EU sales tax, "Value Added Tax"). Kris references 422702501 for JB980 etc (which is also square-section) and that is about 13USD. But nothing more to be gleaned on the spec from this site... and I'm certainly not going to be spending that sort of silly money on a single belt! I currently have 6 decks in need of belts. Yes $13 us dollars is robbery. My pictures may indeed show that the original is approximately 1.5 x 1.5..... But I do not know how to read the gauge. And my whole life I have worked in inches. milometers and kilometers... what is that? I'd have to resort to a conversion chart. The original belts are square, yes and approximately 11/16ths inch in diameter. Quote Share this post Link to post Share on other sites
