Sony Insider Forums
osushipower
SonicStage or Similar?
Hello everyone,
I was digging through an old box I have and was surprised to find an old walkman NW-S603 that I got as a present (bought in Japan). It's been a long while since I last used it, and back then I used to import songs to my walkman through Sonic Stage software. Unfortunately, while browsing the web for more info, I did not find an offline version of this software and most probably lost the installation cd.
I have also watched some videos in which they gave instructions on using MediaGo/Music Center by Sony, but those don't seem to recognize my walkman, might be for another model, most probably.
Any tips on how can I "resurrect" this little guy? Anyone with an offline installer hosted somewhere or another "new" software that might do the job?
Thank you!
Share this post
Welcome!
I don't see NW-S603 listed on minidisc.org. Can you elaborate on make/style?
Comments I just made in this thread might help you get SonicStage up and running on your PC:
Share this post
I don't think it's a MiniDisc player Kevin. Looks like it might be one of these:
Support for NW-S603 | Sony UK
Either way, your advice re SonicStage should hopefully help :-)
Share this post
Doh! (Blush emoji!). I'll get my coat...
Share this post
I have never seen one of these in the flesh, as it were. They date from the era when Sony was producing devices that spoke NetMD, but did not do ATRAC3+ since HiMD didn't yet exist (about 2004). You can check the dates in the manuals. So they should talk to Sonic Stage, and YES will likely need a 64-bit driver (I'm assuming OP has a 64-bit Windows). Unfortunately I honestly don't know whether the NetMD driver is any use for these units. It's only a protocol, but Sony might have modified a bit for their first foray into solid state. I'd need details of what gets installed on a working version, in order to help much.
With the later models there is less problem as you don't need any special drivers to speak Hi-MD, and most people transfer HiMD from SS to begin with.
My first suggestion would be to run Virtual PC as I do for M-Crew (ie PC-Link PCLK-MN10 or -MN20). You then end up attaching the supplied 32-bit driver to the 64-bit stub, using a pull-down menu of VirtualPC after it loads.
The other problem I have not myself grappled with is whether VirtualPC even works with Windows 10. Can anyone clarify? I use W7 for this. There *is* a perfectly good 32-bit install of Windows 10 but most people never even notice it unless they happened to upgrade a 32-bit W7 at about the right time. This might solve the problem so that the original drivers work correctly.
My own difficulty is twofold:
1. I don't have an NW603 or any other diskless unit which predates ATRAC3+/HiMD
2. most of my W10 installs are virtual machines, and I have not tried attaching USB hardware to them.
Sorry not to be of more help, but the driver is surely the problem.
Share this post
Great! Sounds like it behaves as a generic "Atrac Device". This is so for many Japanese-market machines. The export equivalent, especially the more recent ones, this is less true.
Share this post
