Sony Insider Forums
M1JWR
Test Jigs
might try simplified to start with, super glue ribbon onto pcb and solder wires to ribbon connectors and the rest would be like the one in the first pic more or less
ive got one that i can cut from that scrapped 520, the one that goes from the display board to main pcb, can cut that to the 7 connectors at either end. that display is a bit fubar'ed anyway, a lot of dead segments.
Share this post
Yes, that would nicely work.
You may want to make - sort of - strain-relief cuts for the flat ribbon, by opening 4...5 holes in line into one straight hole, with a carpet cutter knife, and make two of them in parallel in say two holes distance.
Share this post
nope cant do that, eyesight not good enough even with magnifying lamp and twp pairs of glasses, cant solder that small,even with wrapping wire around end of iron etc etc,  no cigar i am afraid, have through hole board connector from scrapped cd player, its 22 pin though, could modify that maybe and wire up only 7 of its pins, and cut other end of ribbon at deck end, have that old bd board for test fitting, otherwise are these the female ends needed, never delt with this firm before, would get 5 incase of f ups.
https://www.enrgtech.co.uk/buy/product/ET11659376/52806-0710
Share this post
I have one of these with the intention of removing one socket and adding some test pins.
https://www.ebay.co.uk/itm/1-0mm-Pitch-7Pin-to-7P-Extension-Connector-Aapter-for-FFC-FPC-Cable-Extend-ZIP/362650010017?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
There are breakout boards available but they only seem to come in the even pin-count versions. I have an 8P version with the thought of making it work with the 7P FFC, but there is a risk of me shorting two cores and damaging the machine so I'm not convinced by that approach.
At some point I need to set up the drive in my working E10 (motherboard taken from another E10 unit) so I need to get the 'ole LPM out and make an IOP board...
Share this post
You can get a ten pack of an SMD 7 pin FPC socket for the price of one of that extension connector.
https://www.ebay.co.uk/itm/10Pcs-FPC-FFC-1mm-1-0mm-Pitch-7-Pin-Drawer-Flat-Cable-Connector-Top-Contact/172243355965?hash=item281a81093d:g:x8kAAOSwB9xXPDaj
I admit though that not everyone is familiar/comfortable with making their own pcb. Should you want to go that route, I can share the film layout I made for my jig. I just found it among other photos by accident. Maybe I open a business for making MD test jig boards :-) !
Share this post
Correct.
Kevin came up with the idea of using that extension board, that would save him fabricating a pcb. My reply was meant that the 7 pin standalone sockets are available and cheaper, and he might either use them on an 8 pin breakout board without risking a short circuit, or make his own board like mine, if he wanted to, for what I have the film layout.
But as we are here, let me ask you if the two you (also, Stephen?) are interested in a jig board, with the 7 pin SMD socket already soldered on it and drilled for the test pins. You can then add/solder the pins you like and use your own ribbons. At no cost to you, even postage is minimal for such a tiny item. Let me know - sometime during the winter I will have to make one for a friend, and once I am already in those chemicals, I can do two or three more within the same "overhead".
Share this post
Yep if you can get a batch of PCBs made I'm up for one or two. Even the blank PCB will do me if easier for you. I can just about solder 1mm pitch SMD.
But you won't be doing it for free, I'll pay the dues gladly.
Kevin
Share this post
31 minutes ago, NGY said:
Correct.
The correct response (by me) to that is a question: "Is the Pope (a) Catholic?"
Of course, and I'll happily pay for postage to these distant shores from Pest
Thanks!!!
Stephen
Share this post
no problem with postage this end either, i actually have one on that old bd board, sooner you than me, those pins are tiny, much appreciated, there is still that link also for through hole type if anybody interested meantime.got an old cassette deck to mess about with for now.
Share this post
Great, I will make them in the very near future.
Apologies if my wording was ambiguous - I did not mean you'd have to pay for postage. Quite the contrary. "At no cost to you", plain as it is.
I will send a PM to all of you when the boards are ready.
Share this post
i have made a jig for mdm 7's its crude but it works and have tested it on two decks that i will report on shortly, i recieved the 7 pin ribbons, so i removed the female part from the knackered mdm 7 bd board that i have and stuck it to a piece of veroboard, and to cut a long story short about delicate soldering, it works, i checked for shorted pins first and by miracle it hasent any, the other side of the pic is the usual pins like on the mdm 5 jig, so nothing new to see there, the two players were a 470 and a 940, the 940 was a little more comprehensive in the details i will put down. the 470 first s/n6606247, i bought it needing a new belt though another repair was needed as the board behind the ams had a couple of hairlines through tracks that made the ams push function u/s, a wire link was put in and now is good, i think both these players suffer from the 1hr thing in the history because basically thats all both have, on the 470 its 0.9mw$11 at 19.3 and 7mw is 53.4 (54.4 on sticker)
the first deck i ever bought to fix was this 940, it had a broken drive unit, its not a uk model, i bought another drive unit that had a shot owh, so i put on its original owh and all is good, somebody had removed two of the optical and 1 coaxial jack out of the back, i got replacements from a scrapped 510 board i bought from the bay for little money, i found that 1 optical did not work, and somewhere there is an invisible hairline through a track, a wire link fixed that, so all is 100%.
s/n 5503208 0.9mw$11 18.0, 7mw 52.1 (53.5 on sticker)op and play 1hr each spdl time 2hrs, retry error r00 p93, total ff, error history i think there is 5 positions and they are either 30 or 31,
might try some others over the weekend
Share this post
You’ve been busy! That’s some good debug and repair you’ve done on that set of decks. All brought back from the dead- good news!
Share this post
Great job, well done. You must begin somewhere.
You see, it all started in the early stone age, tools were crude but worked - and now were are in the age of space- and "nano" technologies.
Share this post
i have checked 2 other ex repair decks today, both bought on the cheap needing belts some months ago, infact i remember the 480 needed nowt, seller error, got one anyway.
470 s/n 5516667 0.9mw$11 19.9, 7mw - 54.1 (sticker says 54.4), retry error 3E P29, total D4, History 00-30, 01-10, 02-51, 03-10, 04-50, 05-51, 06-10, 07-51, 08-10, 09-51
480 s/n6682482 0.93mw$11 17.9, 7mw - 50.4(no sticker), rec time 25 mins, play time 239hrs, retry error R00 P58, total 77, history 00-31, 01-51, 02-10, 03-31, 04-51, 05-31, 06-51, 07-31, 08-20, 09-51. will have to have a read at what those history figures are all about, no doubt the key player will be that 440 that got a replacement bd board some time ago, will see what i can dig out next
Share this post
another two tests, i'll not bother with the error history, though i wrote them down if needed, just that 440 with the fresh bd board to do though i will have to ratch that one out, next weekend for that one, and the 980, i'll leave that one alone, ive had it many years and i know whats its done.both these two were spares or repair needing belts.
440 s/n 602565, 0.9$10 17.9, 7mw 53.2 (53.7 on sticker), retry error b 5 p ff, total ff
470 s/n 5502169 0.9$11 16.2, 7mw 48.5 (49.7 on sticker) retry error r ff p 13 total ff
still think the 440 is better build than 470 and 470 in turn is better build than 480, lots of wire jumpers in those two, 440 has proper populated through hole components on circuit board.
Share this post
