Sony Insider Forums
Webmaster
11/21: Wild MZ-R700/R500 Hack
I have been looking for a RM-MC11EL....found one for about $50US.
That's a bit high for me now....Christmas and all coming up.
Would it be backlit running on a R700? also, could a MZ-R55
remote do the same thing?
I bought my R700DPC open box and it came with a RM-MZ3R
remote for some reason. The remote wasn't working perfectly
when I got it, so I opened it and fixed it.
I was wondering if I could modify this remote and add the 2
extra buttons? the hack page has the ohms for each buttons
so it could be possible..?! right? anybody think so?? have any
ideas?!
very interested in this... Michael L
Yes, the baclkight works even when running it on the MZR-700, if you get a MZR-55 or an MZR-90 remote u cannot use any of these features bacause they were added in to the new series... so therefore... the extra buttons wouldn't be on the remote...
Share this post
MOV1, the people who broke their MD units with this trick didn't break MZ-Rxxx units, or at least that what it seems to me. The people who messed up their units are like me and got frisky with an MZ-Nxxx recorder. (Yes, somewhat stupid, I know. Something went weird with mine when I tried to reset the values; I got in service mode, and suddenly all the buttons on the unit stopped working WHILE I was in service mode. Dammit.) I hope Eric gets you that recorder hook up soon, NetMD has made me lazy and I'm out of practice recording things in realtime. Anything I can do to help you out? If you want, I might be able to hook you up with a (dead) MZ-N707 that is (theoretically) fixable if reset...
Share this post
OK,
I know that MOST people broke the N series, but still, this guide is not only for people that broke it doing my hack, but for ANYTHING that they messed up in the service mode (while for example playing around).
About the NetMD- it's on it's way as we speak. I hope the mail service won't mess-up anything...
And about the values that another guy is proposing in an another thread of the forum:
Sure, they'll work, since the numbers are in ascending order, and os are the functions. I gave you gouys those values, because they give the most functions, but if somebody want's less, because he doesn't like some, go ahead-They'll work perfectly.
Share this post
Guest Anonymous
Hi,
with the N707 you can get following features:
Personal Disk Memory (remembers volume, program play, equalizer, and speed settings for 20 discs).
M-Timer (an alarm clock settable in minutes -- so you don't miss your train stop).
Auto time mark (inserts a track mark every 5, 10, or 15 minutes during recording).
Titling in Japanese Kana character set (as well as the normal Roman alphabet).
microphone sensitivity (HIGH/LOW)
selectable audio output modes (Headphone/Line Out)
Adjustable playback speed (from -80% to +110%).
All buttons function normally.
I don not care for any modifications you do on your MD-Player:
Warning: These modifications require that you enter service mode on your unit. It is easy to render your machine inoperative in this mode. I make no guarantees that this will not happen to you! Proceed at your own risk. If your machine does not display the values indicated, exit service mode by removing power -- this procedure may not be suitable for your machine.
These modifications are made from the keyboard, proceed as follows:
Run from the AC adapter or a fresh battery.
Unplug the remote.
Display Description
The MZ-N707's LCD display has two sections, the dot matrix field on the left where titles are displayed, and the 7-segment section on the right where numbers (e.g. time values) are displayed. We will refer to these respectively as the "left display" and the "right display".
Enter service mode:
Set the "HOLD" switch on.
While holding down the VOL - key like a SHIFT key, enter the key sequence:
i.e. FF FF REW REW FF REW FF REW PAUSE PAUSE
Release all keys.
If you have successfully entered service mode, the display will alternately display the firmware version in the left display and a screen with all LCD segments lit at about half second intervals. This work was done on a machine showing Ver 1.300.
Change Setting 1:
Press VOL + -- you should see "MANUAL" displayed on the left and "0 00" on the right.
Press PLAY -- you should see "Laser" on the left and "0 10" on the right.
Press VOL + 5 times -- you should see "F Code" on the left and "0 60" on the right.
Press PLAY -- the first 3 digits of the left display should be continuously incrementing. The last 2 digits of the left display are a value in memory that you want to change (it probably reads "A0" for the MZ-N707 and "??" for the MZ-N505, but write this number down!). You should see "0 61" on the right.
Press VOL + repeatedly until the last two digits of the left display read "FE" (you can press VOL - if you go past it).
Press PAUSE
Change Setting 2:
Press PLAY -- you should again see incrementing numbers in the first 3 digits of the left display and "0 62" should appear in the right display. The last two digits of the left display are the value you want to change (it probably reads "50" for the MZ-N707 and "??" for the MZ-N505, but write this number down!).
Press VOL + repeatedly until this reads "7B" (you can press VOL - if you go past it).
Press PAUSE
Exit service mode:
Remove power plug or battery.
I hope it does it also with the 505. (please write me an e-mail with the ??-Factors)
The NetMD-Transfers are not affected by this modifications.
Sorry for mistakes (I'm german)
rio17@web.de
Share this post
Guest Anonymous
w00t! Guest, whoever you are, I thank you!
I knew absolutely nil about what I was really doing, but just now I tried Guest's instructions, with much trepidation, on my MZN-707. I followed the instructions exactly and slowly to make sure I didn't make any mistakes. The result? Success! Everything works perfectly and the added features are indeed there.
If any of you are considering the hack on an MZN707, I say do it! But do it carefully and slowly. Don't make a mistake!
Again, thank you thank you thank you!
Share this post
Guest Anonymous
Has anyone tried this on the MZ-R501 yet?
Just treat it as MZ-R500 (They are actually identical)
MZ-R501 has the menu 062 default as S30 instead of S20 in R500
Share this post
Guest Anonymous
I don't know if Iposted correctly. I own a mz-r700 and i am wondering if any one has figured out how to change the setting for the memory systems. What i mean is that as most people klnows that there is g protection in the md right?. What people don't know is that the g protection is only activated when it receives a shock!(when tou bump it to make it skip. All the othern times it is using a 60 secound shock prtection. that means it only accesses the md every 60 secounds for loading 3-5 secounds of music data. Now after all te explination the new net md's have a 95 sec memory buffer. does any one knows how to change the settings so that I can change the memory buffer? perhaps to a 95 secound or longer? I hope some one else knows how or if that it even exists. Thanks to the insane hackers.
**Note: To those who want to know alittle bit more the G-protection is only accessed when you try to bump it.(as mentioned above) Once activated it will access information every 3 sec. for 1 sec. (reads 1 sec for every 3 sec) This will go on till you don't skip it any more. Basically that is the low down on the g-protection. 8)
Share this post
About the previous post about the G protection:
The G protection is handled internally in the CMOS and it is impossible to change the routine. That would also need a software re-write, and I think i told everybody what that means on the R series. iN the N series however, there is a software uploader, but people from OpenNMD are playing with those, so ill just wait for them, unless i find something VERY interesting.
Share this post
Guest Anonymous
I am just wondering does anyone know what all the menus mean? ie manual, opt ajt etc. and actually has anyone actually crack the code for the thing yet so that you know what all it all means??? I managed to find out that there are quite a bit of differnces between the n505 to the n707 small but very similar changes. If any one knows what all the changes do please post us. And actually if anyone owns a N1 and has alot of time can they please post all the settings ?To my understanding you can not change anything setting wise as long you don't press the pause button! Also if anyone has a r900 can they post all the settings too! This way people can better analyse the system and hopefully figure it out. if this dose not work someone please tell me! But hey it dosen't hurt to try it!
Share this post
Yes, I AM ACTUALLY MAPPING EVERYTHING in the service mode as we speak. There are no manuals whatsoever that do this, so I'm on my own. I still have a couple of things to crack. If anyone knows what does the Japanese word
-Keisu
mean, please mail me.
Share this post
-Keisu
i do japanese at school... and i believe it means 'chair'
but.. i will ask around for u next week...
Share this post
For the past week iv'e been fighting with my MD for the last thing that isn't in my hack- The Date/Time stamp. ANYONE, I BEG YOU, HELP PLEASE! If anyone has a 900 or similar, please, can you give me ALL your values from master functions 0,5,6,8 and 9. Until I don't have that, i don't think the hack is finished. Also can anyone try out what does the value 0 64 (SysFlg- clearly stands for System flag) do and what value does it have on a 900 or similar.
Hope i can get some reply. Please, people with 900 and so on, I think the people that have lower models wil be forever thankfull for this.
With regards
M0V1
Share this post
This hack is impressive -- my 707 just got a lot more interesting. smile.gif
Unfortunately, I have to add in my observation that Personal Disc Memory is not working for me. Whenever I have a disc in and choose to make an entry, the system seems to work; when I choose "Erase", it finds an entry and erases it. However, when I remove the disc and then reinsert it (regardless of whether or not I'm using battery or AC power), the unit seems to lose the entry. If I go to PERSONAL and choose ERASE, the system blinks "No Entry!" for a couple of seconds before going back to sleep. I wonder if perhaps the memory layout and power usage of the 707 precludes these values from being retained?
It's a relatively minor negative in the midst of a lot of positives. Thank you for the work on this; I would love to hear/see more of the engineering effort that helped uncover these features.
Share this post
-Keisu
Share this post
Guest Anonymous
I just did the hack on my N505. I tried personal disc memory as you suggested and it did not work. I have an N10 also so I know what it should do and although it seems to accept the entry, it does not live through the disc change.
Share this post
Hi, that last post was me, but not logged in. I also tested melodytimer on the N505, as the R500 was reported in this thread as not having beeps in melodytimer. On my N505, the melody works fine. You get a funky electo melody to wake you up before your next train stop.
Share this post
Guest Anonymous
Well, after "hack" mi MZ-R700 all those new functions where avaible but... Now I can't charge my battery!! :shock: Please, someone who has hacked his unit please tell me if it is due to the hack, or it's my problem. Thank You. sad.gif (sorry about my english, I'm spanish) :wink:
Share this post
Guest Anonymous
I can't charge my battery neither, but I have a mz-r500 wink.gif, in this unit there's no beeping funcion, there's no battery charging, there's no Bass and Treeble control.. I want THAT! hehe, I've made a remote control (with some resistors and switches) for my MD (the unity has a flat remote control connector inside battery's compartment), and If I press the sound key for more than 2 seconds (as 900's manual says) nothing happens *sight*. I want to know how works the values in that service mode, I nees a map or something equivalent. Excuse my english , I'm Spanish too. you can mail me at Schrei@wanadoo.es
Share this post
Guest Anonymous
Inside battery's compartment there's a little hole, and u can view a little connector with four coppered pins, you have to put a resistor between pin 1 and 3 (RVCC and Rkey), There's a table with the values of the resistor for giving a key-function (for example 2,4k Ohm for Sound function from 900's manual). It's only for educational propposes, My remote control isn't useful at all. If you see at Service Manual's diagrams , you'll find more surprises smile.gif
Greetings.
Share this post
Guest Anonymous
Hi there!
I've done this hack and everthing works fine
i get those all new features, but i found a problem
for my surprise when i've try to write a track name and all
caracters look like chinese :x
I change everthing back to normal and it was all Ok
my MD is a MZ-R700 PC
Does this happen to anyone or i made some error?
Greetings
Share this post
hey guest...
that's weird that your characters look different. i think you did something wrong. I recommend giving it another shot, that didn't happen with mine. sounds kinda neat though...
Share this post
