lixuelai Posted April 25, 2005 Report Share Posted April 25, 2005 (edited) I planned on getting a rh10 over an rh910 but now seeing that i can get a rh910 for around 160 USDS as compared to 282 USDS for the rh10 im doubting myself. The rh10 im getting (if i get it) will be the Japanese domestic version. Now is rh10 really worth it? And is there any major difference between the two besides accessories and rh10 looking alot better? Im wondering for one whether rh910 has virtual surrond sound. Anyway any suggestion will be great. Really wondering why there is a 120 dollar difference when as far as i can see they are pretty similar. Thanks.p.s. Does the Rh10 have a HD Amp?anyway i know there are some topics about this already but none really lists the difference between the two in terms of specs. Or is there none? Edited April 26, 2005 by lixuelai Quote Link to comment Share on other sites More sharing options...
Woodgnome Posted April 26, 2005 Report Share Posted April 26, 2005 Main differences:-RH10:-Does not have cradleHas EL display (better)Does not have LCD on remote (worse)Does not come with free 1G Blank MD! (worse)Editing & erasing tracks does not "necessarily" work on NH900 (bug with 1st Gen units - doesn't effect you if you only download tracks in an i-pod esque way / use unit for playback only)Cannot record (old fashioned) MD (SP) on unit (although can download to unit from PC in MD SP to the 80minute blanks)Battery life 32h (instead of 37h on NH900)Equalizer (VH Engine) Cannot gain access to custom presets on Eurpean Model (V. V. Worse!!!)Cannot show all time remaining on the disks when playing (odd that one...)Can be powered (charged) through USB cable directly (NH900 only through cradle which is plugged in to mains adapter)That's about it - only had my RH10 for 2 days!Conclusion - get the NH900 if you don't do much recording of original music (as track editing / moving / erasing doesn't work as per specification on "some" models)- if you need to record - it's the RH10 - you'll need some excellent earphones without the VH+ customizable presetsGood luck Quote Link to comment Share on other sites More sharing options...
FrzzMan Posted April 26, 2005 Report Share Posted April 26, 2005 Man I think he's asking about the differents between rh10 and rh910?!?!?!?!?@lixuelai: Where can you get that rh910 for $160??? :drool: Quote Link to comment Share on other sites More sharing options...
streaml1ne Posted April 26, 2005 Report Share Posted April 26, 2005 The US model comes with a 1gig disc. datavis.com has the RH10 for $240. The screen is the big attractor on the RH10 and I think it's worth the extra money alone. You'll never need a backlit remote again (unless you prefer them) and it's perfectly readable even when dimmed from just about any angle. Quote Link to comment Share on other sites More sharing options...
jillako Posted April 26, 2005 Report Share Posted April 26, 2005 lixuelai said: i can get a rh910 for around 160 USDS as compared to 282 USDS for the rh10←I'm interested too. $160 is pretty affordable.. can you share where this price is available? Quote Link to comment Share on other sites More sharing options...
lixuelai Posted April 27, 2005 Author Report Share Posted April 27, 2005 There was one one ebay for that much. Right now there is one at $169. Close enough Quote Link to comment Share on other sites More sharing options...
pablito Posted April 28, 2005 Report Share Posted April 28, 2005 so the response was mistakenly referring to the 900 and not the 910 right? So what ARE the substantive differences between the rh10 and the rh 910? Is the display the only thing? Quote Link to comment Share on other sites More sharing options...
lixuelai Posted April 28, 2005 Author Report Share Posted April 28, 2005 Well the only way to find out i guess is to compare the manuals for the two. I got a 910 manual already and since ill get the rh10 i can compare the two. I believe rh10 have virtual surround sound. 910 i know does not. Quote Link to comment Share on other sites More sharing options...
