peon Posted September 21, 2005 Report Share Posted September 21, 2005 Can you guys tell me your opinions or perhaps link reviews of these trhee players? i don't know which to get. does the n1 have a backlight on the unit not just the remote? im new to mini disc players thanks. Quote Link to comment Share on other sites More sharing options...
bland10000 Posted September 21, 2005 Report Share Posted September 21, 2005 At the minidisc.org page, look to your right and in the first vertical row is the heading "equipment". Go to equipment browser to have a look at these descriptions...N1 product descriptionN10 product descriptionN910 product description Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted September 21, 2005 Report Share Posted September 21, 2005 They're all excellent recorders, but somewhat old-hat. They've all long since been superceded by the Hi-MD units, which you may care to look at... The Hi-MD recorders are far more powerful and add a host of new exciting features to the standard NetMD facilities...I'd suggest something like the RH910 would be an excellent starter model... Quote Link to comment Share on other sites More sharing options...
Sparky191 Posted September 21, 2005 Report Share Posted September 21, 2005 ...I'd suggest something like the RH910 would be an excellent starter model...and a torch so you can see the screen at night... Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted September 21, 2005 Report Share Posted September 21, 2005 Well, OK, then the RH10... Quote Link to comment Share on other sites More sharing options...
yakman Posted October 7, 2005 Report Share Posted October 7, 2005 (edited) Can you guys tell me your opinions or perhaps link reviews of these trhee players? i don't know which to get. does the n1 have a backlight on the unit not just the remote? im new to mini disc players thanks.When let ppl help u decide what to buy, u should let know what's u proposed usage of the MD set: )If u r buying as a player for listening to music, honestly I recommend U a good quality mp3 player, much easier to use, with competitive sound quality, If U really care about sound quality a lot, CD player would be a better choice.If u r buying as a recorder for recording live concerts, yes, MD is a good choice. I recommend U get a HiMD instead of NetMD. It's nearly impossible to digital upload Net MD recorded music to PC.FYI.sth U need to watch out when buying, N1 or N10, since new sets hard to find.N1 got famous ribbon cable problem, dun buy if U r not strong in DIY repair... btw, no backlight on setN10, battery not replaceable.N910, never use before, no commentGood luck, heh Edited October 7, 2005 by yakman Quote Link to comment Share on other sites More sharing options...
veezhun Posted October 7, 2005 Report Share Posted October 7, 2005 well said yakman..go for hi md if you want to record.. go for a HDD based device if you want a player,... Quote Link to comment Share on other sites More sharing options...
ynos Posted October 7, 2005 Report Share Posted October 7, 2005 well said yakman..go for hi md if you want to record.. go for a HDD based device if you want a player,...Agree! Quote Link to comment Share on other sites More sharing options...
