9goldfish Posted October 25, 2005 Report Share Posted October 25, 2005 HiI want to buy a MD player to record high quailty CD's for resale, they will be nature and water sounds. I have been looking at the Sony MZ-RH10 but i am now put off because i will need to download to my computer and edit the sounds and also add some voice over.From what i can tell is the software will restrict and also what i have heard about Sony copyright software built in.Can anyone please tell what MD i should get, it must be high quailty recording in stereo.many thnaksMichael Quote Link to comment Share on other sites More sharing options...
mkeswani Posted October 27, 2005 Report Share Posted October 27, 2005 Michael,The RH10 should work fine for you. I have an NH900 with mic-in and have been making live music recordings in PCM mode (16 bit, stereo) with no problems. SonicStage 3.2 does not restrict in any way how you manage any recordings made from line-in or mic-in. They are saved on your PC in WAV format and you can edit as you like.Suggest you look through the forum to choose the best model to suit your requirements.Regards,M Quote Link to comment Share on other sites More sharing options...
veezhun Posted October 27, 2005 Report Share Posted October 27, 2005 HiI want to buy a MD player to record high quailty CD's for resale, they will be nature and water sounds. Resale?? You mean you want to sell these high quality cd's that are copied through the Hi MD? Are these your own CD's? If not, I believe this is gross violation of copyrightsCheers Quote Link to comment Share on other sites More sharing options...
Richard Posted October 27, 2005 Report Share Posted October 27, 2005 Resale?? You mean you want to sell these high quality cd's that are copied through the Hi MD? Are these your own CD's? If not, I believe this is gross violation of copyrightsCheers I understood him to mean he wanted to do field recordings via Md of environmental sounds, burn to cd via computer and re-sell. So in a sense they are his own recordings - unless I misread him. Quote Link to comment Share on other sites More sharing options...
veezhun Posted October 27, 2005 Report Share Posted October 27, 2005 Oh ok. Sorry bout that... My mistake cheers Quote Link to comment Share on other sites More sharing options...
9goldfish Posted October 27, 2005 Author Report Share Posted October 27, 2005 I want to record wildlife and nature sounds like waves, thunder storms etc. Hopefully Sony do not have copyright on this yet? Thanks so much for all your advice, bearing in mind what i want to do (recording mainly), what would you say the best machine is for me?Kind regardsMichael Quote Link to comment Share on other sites More sharing options...
jadeclaw Posted October 27, 2005 Report Share Posted October 27, 2005 Nature sounds are still free to use. I would say, either the RH910 or the RH10.If you use it a night, take the RH10.If you use a Mac for Editing, take the MZ-M100. Quote Link to comment Share on other sites More sharing options...
9goldfish Posted October 27, 2005 Author Report Share Posted October 27, 2005 Thanks for that. Can you tell me if the SONY MZ-NH1 is better than the other two?many thanksMichael Quote Link to comment Share on other sites More sharing options...
lyceemoliere Posted October 28, 2005 Report Share Posted October 28, 2005 (edited) Would people have the same suggestions for recording lectures? does the size of classroom matter or do these work equally well in a large lecture hall or a small classroom? Edited October 28, 2005 by lyceemoliere Quote Link to comment Share on other sites More sharing options...
greenmachine Posted October 28, 2005 Report Share Posted October 28, 2005 It's mainly the type of microphone and their placement that determines the resulting quality. All (Hi)MD units have reached a very high quality standard that can or cannot be limited by additional equipment. Focus your attention on external equipment and your recording technique. Quote Link to comment Share on other sites More sharing options...
djrobin458 Posted November 2, 2005 Report Share Posted November 2, 2005 Nature sounds are still free to use. I would say, either the RH910 or the RH10.If you use it a night, take the RH10.If you use a Mac for Editing, take the MZ-M100.Excuse me for butting in but I'd like to ask two questions:1) Isn't the RH10 the same as the MZ-M100???2) Why the MZ-M100 if using a Mac?Thank you,David Quote Link to comment Share on other sites More sharing options...
