bobert1 Posted February 8, 2006 Report Share Posted February 8, 2006 whats the easiest way to get my minidisc collection onto the hard drive of my laptop??. My minidisc player has both optical and coaxial outputs....HELP! and thanksrob Quote Link to comment Share on other sites More sharing options...
Christopher Posted February 8, 2006 Report Share Posted February 8, 2006 Welcome. Erm, what Minidisc player do you have specifically? What model number? Quote Link to comment Share on other sites More sharing options...
bobert1 Posted February 9, 2006 Author Report Share Posted February 9, 2006 (edited) Welcome. Erm, what Minidisc player do you have specifically? What model number?Thanks I have a uk special edition sony minidisk deck MDS-jb940, it's a few years old now, may be 5(?) but i love it and it has served well......i will hopefully use it for years to come??!!!!rob Edited February 9, 2006 by bobert1 Quote Link to comment Share on other sites More sharing options...
Roamer Posted February 9, 2006 Report Share Posted February 9, 2006 Then the best is probably to go optical out to an external sound card with optical in, and record in real time with audacity or similar tools. Check the pinned thread for more detailled 'how to'. Quote Link to comment Share on other sites More sharing options...
Christopher Posted February 9, 2006 Report Share Posted February 9, 2006 Roamer is right, bobert1. If you have any confusion over that process just reply to this topic accordingly with your woes.. Quote Link to comment Share on other sites More sharing options...
bland10000 Posted February 9, 2006 Report Share Posted February 9, 2006 If I go digital-out from a deck to digi-in on a md-recorder, I get a "no-copy" message. Why would digi-out from a deck to a digi-in on a computer be different? Quote Link to comment Share on other sites More sharing options...
Christopher Posted February 9, 2006 Report Share Posted February 9, 2006 Good point, bland. Not all optical scenarios can work okay.Hence, http://forums.minidisc.org/index.php?showtopic=7070 Quote Link to comment Share on other sites More sharing options...
Shozzer Posted February 9, 2006 Report Share Posted February 9, 2006 Am I right in saying that there are some soundcards with optical input which (ahem) do not worry about SCMS? I am sure that any recommedations will be greatly received! Quote Link to comment Share on other sites More sharing options...
bland10000 Posted February 9, 2006 Report Share Posted February 9, 2006 oh yeah, that SCMS thing...that explains why I can't record from digi-out of my deck to md. So how about soundcards? Quote Link to comment Share on other sites More sharing options...
pauljones52 Posted February 9, 2006 Report Share Posted February 9, 2006 (edited) oh yeah, that SCMS thing...that explains why I can't record from digi-out of my deck to md. So how about soundcards?My Soundcard has a digital out, which my minidisc wont record from digitally. But it will let me copy if I turn on digital out from the volume control after a restart. If I stop and try to record again I get a no copy message, but if i restart my computer I can record again. Edited February 9, 2006 by Matt J Quote Link to comment Share on other sites More sharing options...
bland10000 Posted February 9, 2006 Report Share Posted February 9, 2006 I record from my digi-out on the computer to md and hi-md recorders all the time without any hassle. I'm wondering if SCMS rules/ laws apply to sound-cards regarding copying from md-deck digi-out to computer digi-in.MattJ, sorry to read about the hassle you have to go through... Quote Link to comment Share on other sites More sharing options...
pauljones52 Posted February 9, 2006 Report Share Posted February 9, 2006 wish it was as easy as that for me bland10000! What program do you use to play whatever you are recording from? Does this make any difference or does it depend on your soundcard. Quote Link to comment Share on other sites More sharing options...
bland10000 Posted February 10, 2006 Report Share Posted February 10, 2006 wish it was as easy as that for me bland10000! What program do you use to play whatever you are recording from? Does this make any difference or does it depend on your soundcard.I don't think the program makes a difference. I use Real as my library but also have songs loaded in SS, WMA, and Musicmatch and I can digitally record via the soundcard from all programs. Quote Link to comment Share on other sites More sharing options...
KrazyIvan Posted February 11, 2006 Report Share Posted February 11, 2006 Most sound cards just ignore the SCMS flag hence copying to computer is not hindered. The rules for copy protection did not apply to computer equipment. That is changing. There are some sound card appearing that do respect the SCMS flag. Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted February 11, 2006 Report Share Posted February 11, 2006 Most sound cards just ignore the SCMS flag hence copying to computer is not hindered. The rules for copy protection did not apply to computer equipment. That is changing. There are some sound card appearing that do respect the SCMS flag.I've found reporting of this to be very inconsistent. Some SP/DIF inputs on sound cards will allow anything to pass [sCMS ignored];Some won't allow anything to pass except for "monitoring" [using the sound card as a DAC];and Some respect SCMS.If you are looking at a sound card or USB adapter with SP/DIF inputs [optical or coax], I'd suggest searching the net for tech and customer reviews of the units you're looking at first. Also, reading the full specs or operations manual of the product will sometimes specify how it deals with SCMS. Quote Link to comment Share on other sites More sharing options...
astranomical Posted April 18, 2006 Report Share Posted April 18, 2006 If you are looking at a sound card or USB adapter with SP/DIF inputs [optical or coax], I'd suggest searching the net for tech and customer reviews of the units you're looking at first. Also, reading the full specs or operations manual of the product will sometimes specify how it deals with SCMS.Has anyone tried this with various sound cards? Can anyone provide a Yes/No on theirs? I am looking at a HDA X-Mystique 7.1 Gold with Digital I/O board but will change if you can suggest others that will work Quote Link to comment Share on other sites More sharing options...
