SonicStage skins
hkey_barker
I stumbled across a link that had some SonicStage skins. Thought I would share this with whoever is looking for different skins.
Just download to C:\Documents and Settings\All Users\Application Data\Sony Corporation\SonicStage\Skins (default directory)
and remove the '.zip'
http://www.sonymatome.com/sonicstage/index...%DD%B4%C9%B8%CB
Sweet! I never know you could get skins like that! :)
The framework is similar to winamp skins!
<skin>
    <background src="base.bmp" transparent="1" />
    <slider id="volume"    x="22" y="14"  thumb="sliderv.bmp" channel="chv.bmp" />
    <slider id="position"  x="19" y="67"  thumb="sliderp.bmp" channel="chp.bmp" />
    <button id="close"     x="99" y="14"  src="close.bmp" />
    <button id="fullmode"  x="79" y="14"  src="full.bmp" />
    <button id="minimize"  x="89" y="14"  src="min.bmp" />
    <button id="playpause" x="48" y="207" src="play.bmp" />
    <button id="previous"  x="13" y="170" src="prv.bmp" />
    <button id="next"      x="83" y="170" src="next.bmp" />
    <button id="menu"      x="48" y="133" src="menu.bmp" />
    <button id="voldown"   x="14" y="14"  src="voldown.bmp" />
    <button id="volup"     x="69" y="14"  src="volup.bmp" />
    <static font="MS UI Gothic" size="8" forecolor="333333">
        <text id="albumname" x="19" y="26" width="82" />
        <text id="trackname" x="19" y="39" width="82" />
        <text id="artist"    x="19" y="52" width="82" />
        <text id="time"      x="19" y="74" width="82" />
    </static>
</skin>
You could make you'r own! :)
Edited by danielbb90
Hmm. There are some surprisingly nice skins there .. I'm really into minimalism most of the time; i.e. a mini-player should be the controls and the most basic play info, period. Those teeny ones that are about the same height as a title bar are really quite functional.
Now if only SS had built-in EQ and support for any Dshow-supported audio format the user has codecs installed for. As it stands, I don't even use it for playing OMA files [i use Media Player Classic with its basic playlist].
I suppose when it comes down to it though, the -only- reason I won't consider using SS as a player isn't because my library is only 50% comprised of MP3s; it's because the acoustics of my living room/studio *REQUIRE* EQ for resonance correction.
  mrsoul said:
I have a decent 5.1 setup, so I get by with the subwoofer controller...
I have logitech z680s. The lack of any EQ whatsoever is painful. A subwoofer level control is NOT adequate to compensate for extreme resonances like the +14dB @ 105hz in my living room. With the sub control alone I can either choose to have actual bottom end with ~100Hz so loud that things rattle off shelves, or no bass whatsoever. PITA.
  mrsoul said:
Really like these skins. Does anybody have the skills to create some more? If so, keep the forum updated. Thanks for the tip! As for EQ, I have a decent 5.1 setup, so I get by with the subwoofer controller...
I can but I don't think I can get motivated enougth to do it!
Its a pritty simple XML script! :)
  • 2 months later...
I found some more skins here http://www.evolbird.com/material/sonicstage_skin.html not as cool as the ones from the sony site though.
  • 3 years later...
  • 11 months later...
  On 4/19/2010 at 5:24 AM, bat21 said:
They're still there.
http://www.sonymatome.com/sonicstage/index.php?%E3%82%B9%E3%82%AD%E3%83%B3%E4%BF%9D%E7%AE%A1%E5%BA%AB%2F%E3%82%B7%E3%83%B3%E3%83%97%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89
I love the Ipod one.. a virtual Ipod - now that I could live with :)
