Ishiyoshi Posted May 17, 2006 Author Report Share Posted May 17, 2006 Ishi, just one question. I would like to buy a sharp boombox (MDLP) that I found here in chile and it has radio-cd-tape-md functions. Do you know if I record anything (radio, for instance) in the MD, it would be possible to upload it using the RH1? Could you give it a try and tell me?please Yes, you can absolutely upload radio recordings done with your Sharp Boombox to the PC via the RH1. Note: you can basically upload any analog in, optical-digital and microphone recordings. The only exception to this is recordings done via the PC or rather transferred over via USB. Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted May 17, 2006 Report Share Posted May 17, 2006 Thanks! I have not coupled the USB-AC Adaptor with either the NH1 or the RH10. I suspect it will not work due to difference in each unit’s respective power requirement.USB power = USB power. The older units with standard mini-B plugs will not work because as soon as they see power [via USB], they expect that they're plugged into a computer [as already described]. The voltage/current thought [as described above] is incorrect, though. If Sony had used non-standard power over the USB connector, it would have been illegal for them to even refer to the device as USB [since they'd be breaking the standard]. Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted May 17, 2006 Author Report Share Posted May 17, 2006 USB power = USB power. The older units with standard mini-B plugs will not work because as soon as they see power [via USB], they expect that they're plugged into a computer [as already described]. The voltage/current thought [as described above] is incorrect, though. If Sony had used non-standard power over the USB connector, it would have been illegal for them to even refer to the device as USB [since they'd be breaking the standard].I thought the power requirement would factor in. Thanks for the clarification, dex. Quote Link to comment Share on other sites More sharing options...
bogon07 Posted May 18, 2006 Report Share Posted May 18, 2006 Ishiyoshi,Yet again fantastic pictures.Look forward to seeing the results of your interbreeding program between the RH1 & RH10/NH1. Looks like the RH1 uses the same USB-Ac Power adaptor as the NWA1000/3000 instead of inventing another new one. Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted May 18, 2006 Author Report Share Posted May 18, 2006 Ishiyoshi,Yet again fantastic pictures.Look forward to seeing the results of your interbreeding program between the RH1 & RH10/NH1. Thanks for the kind comments. You are still waiting for the ultimate Hi-MD unit eh? Quote Link to comment Share on other sites More sharing options...
bogon07 Posted May 18, 2006 Report Share Posted May 18, 2006 Thanks for the kind comments. You are still waiting for the ultimate Hi-MD unit eh? Yep,Something like the RH1 in a metallic bluish black with a colour display like the DH10P.Till then there's your pictures of the RH1. Quote Link to comment Share on other sites More sharing options...
computerguy Posted May 25, 2006 Report Share Posted May 25, 2006 Nice pictures! Also nice to see the first picture of the AC-adapter with USB-connector. [snip]Take a look at the power input requirements of the power adapter!!! It looks like it takes both 110V and 240V. Thus it looks like it is already a World Tourist model. All you have do to is get the plug adapter. RWW Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted May 26, 2006 Author Report Share Posted May 26, 2006 Take a look at the power input requirements of the power adapter!!! It looks like it takes both 110V and 240V. Thus it looks like it is already a World Tourist model. All you have do to is get the plug adapter. RWWMost Hi-MD units since the RH10 come with a worldwide 110V-240V AC Adaptor. Indeed, one would just need to acquire the corresponding plug adaptor according to one's location. Quote Link to comment Share on other sites More sharing options...
whatsleftofj Posted June 9, 2006 Report Share Posted June 9, 2006 Do you notice any significant difference in speed when transferring files to/from the computer as opposed to an RH10? Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted June 9, 2006 Author Report Share Posted June 9, 2006 Do you notice any significant difference in speed when transferring files to/from the computer as opposed to an RH10?File transfer to the PC from the RH1 is indeed significantly faster than the RH10. Quote Link to comment Share on other sites More sharing options...
whatsleftofj Posted June 9, 2006 Report Share Posted June 9, 2006 (edited) Is is sad that that much alone is making me want one? It bugs me when it takes more than 20 minutes for me to make a disc before work.... Edited June 9, 2006 by whatsleftofj Quote Link to comment Share on other sites More sharing options...
Rumz Posted June 9, 2006 Report Share Posted June 9, 2006 I don't know how I missed this thread before (probably because I was basking in the Hawaiian sun when it was posted ) but dang-- Ishi always takes the best photos of gear. If you ever got sick of your day job I bet you could make a good living as a commercial photographer-- you've got skill. And this doesn't help me want the RH1 any less Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted June 11, 2006 Author Report Share Posted June 11, 2006 I don't know how I missed this thread before (probably because I was basking in the Hawaiian sun when it was posted ) but dang-- Ishi always takes the best photos of gear. If you ever got sick of your day job I bet you could make a good living as a commercial photographer-- you've got skill. And this doesn't help me want the RH1 any less Thanks for the kind comments, Mike! Ah.. the sweet breeze of Hawaii. Whereabouts in Hawaii were you? I am planning another short trip to Kohala this August. Quote Link to comment Share on other sites More sharing options...
Sparda Posted September 14, 2006 Report Share Posted September 14, 2006 Nice pictures Ishiyoshi! Am i a bit slow or what, but i didn't know the RH1 came with a cradle..... Lol, if it really does then im missing my cradle....gotta go phone Sony. Or maybe is it only for imported models? Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted September 15, 2006 Author Report Share Posted September 15, 2006 Nice pictures Ishiyoshi! Am i a bit slow or what, but i didn't know the RH1 came with a cradle..... Lol, if it really does then im missing my cradle....gotta go phone Sony. Or maybe is it only for imported models?Thanks for the comment. Please re-read the "Notes" within the pictorial - "MZ-R910’s charging stand was used for the photo shoot." Quote Link to comment Share on other sites More sharing options...
Sparda Posted September 15, 2006 Report Share Posted September 15, 2006 (edited) Yeah i just read it over again and saw the note, my bad. If you don't mind me asking, what camera do you use for taking photos of your units? They are superb.... Edited September 15, 2006 by Sparda Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted September 16, 2006 Author Report Share Posted September 16, 2006 If you don't mind me asking, what camera do you use for taking photos of your units? They are superb....Most of my MiniDiscs/'phones pictorials found in MDCF were shot with the Canon EOS 1Ds Mk.II and Powershot G5. This pictorial was shot with the latter. Thanks for the kind comment. Quote Link to comment Share on other sites More sharing options...
Richard Posted April 6, 2021 Report Share Posted April 6, 2021 * Restoring Ishii's pictorial to it's original glory :-) Quote Link to comment Share on other sites More sharing options...
